Old 06-07-2016, 05:23 PM   #1
Ken Haase
Default anybody want to hazard a guess?
Working on a BBC with T&D rockers. Any idea how much an increase of .100" in pushrod length will move the roller center farther out on the valve stem tip? Need a little more retainer to rocker clearance and the roller is definitely to the inbord side of the valve centerline.
Yes, we could make an adjustable pushrod, but we can make one solid one quicker and try it, since I'm buying a complete set anyway.
thanks
Ken Haase is offline   Reply With Quote
Old 06-07-2016, 05:35 PM   #2
Jeff Stout
Liked 706 Times in 283 Posts
Default Re: anybody want to hazard a guess?
On the TD shaft don't they make thicker shims to go under stands to raise rockers and help clearance. I thought I read that some where.
Sorry just re read post and read you are on inside of valve and could use more rod to get to center and not touch retainer
Jeff Stout is online now   Reply With Quote
Old 06-07-2016, 06:04 PM   #3
Ken Haase
Jeff, you are correct. Only shimming the stands further will correct roller tip to valve centerline misalignment. I called T&D, which I should have done in the first place. Thanks for your reply.
