Liked 54 Times in 24 Posts
Has anyone used Comp Cams short travel hydraulic lifters? Can they be used as is, or do they need modification?
They appear to have more plunger travel than a Sherman type lifter. My concern is I have a COPO customer that I ran his engine on the Dyno with these lifters w/ .010 preload (as per comp) and it lost a lash cap. No one from Comp can seem to tell me how much plunger travel these things have. Reason for concern, any open valve spring pressure while sitting causes plunger to collapse until oil pressure comes up, leaving substantial lash. Thanks- T.G. |
Liked 401 Times in 154 Posts
They do make a couple different styles, short(or reduced) travel, and limited travel. The reduced travel lifters I have will move approx. .065 before solid. The limited travel I believe are listed as either .015 or .025, not sure which.
Phil Molski PMR Performance S/C 1623 |
Liked 1,471 Times in 308 Posts
68 thou. Measured them in a fixture. J.R.
Thanks guys*
I had nothing but constant trouble with them:
1 Retaining clips were tin rather than a clip and broke several while breaking in. 2 Some Lifters would pump down a few seconds after preoiling and bend pushrods upon cranking. 3 Some leaked a lot of oil around plunger. 4 Varied in plunger travel a LOT! I posted about their quality control last year.....Tech line was ZERO help. Left several messages for Tim Cole and never received a return call. Two sets currently residing my weight box.
Banned
Liked 5 Times in 3 Posts
They're definitely more travel than the lifters my dad and i do, I've measured some that had as much as .090" travel. We keep ours at .020" or less and can customize them if customers prefer more or less travel.
#7 | |
P.S. Hard to believe that Tim didn't return a call, he's ALWAYS returned every call I made, a couple times it was the next day, but still called back. Phil
#8 | |
