Old 04-24-2016, 09:40 PM   #11
Jeff Jewell
Jeff Jewell's Avatar
Liked 171 Times in 36 Posts
Default Re: Battery / cutoff switch??
On my Corvette, before I relocated the battery, I had the cutoff switch by the battery under the hood. I then ran a Morse cable to the rear of the car. Completely legal for the shutoff requirement. Just a thought...
Old 04-25-2016, 09:22 AM   #12
Bobby DiDomenico
Liked 101 Times in 52 Posts
Jamie,
Have seen a lot of cars as the others mentioned with a on/off switch or the bar that raises to break contact attached to the post..
That 75 amp draw is just with the say "key on", nothing actually running??
Old 04-25-2016, 10:31 AM   #13
Alan Nyhus
Liked 800 Times in 237 Posts
Jamie, I mounted a 300 amp master switch on the dash. Ran the power to it using a 4 ga. cable from the + bulkhead terminal on the firewall and from there to the main circuit board. Nice to be able to cut the power if you need to. -Al
"That'll never work....."
Old 04-25-2016, 10:47 AM   #14
Eman
Liked 133 Times in 76 Posts
I'm thinking 75amps is the rating of the panel with all circuits combined. I'm guessing you're not using relays on anything and the switch panel has fuses and they are carrying the total loads. I wouldn't want a panel that's lit up when the car is off but I guess that's how it's made.
If you want to shut it down you can do as Alan Nyhus stated or use a continuous duty solenoid/relay. Cole Hersee makes quality solenoids and switches.
Old 04-25-2016, 10:59 AM   #15
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
My battery is in the trunk with a cutoff switch, but the main power coming into the cabin still runs through a 150 amp circuit breaker just to be on the safe side. Since it can be operated like a switch manually you could mount it on the dash or somewhere accessible and use that as your cutoff.
I used to run the charge wire from my alternator through the cabin to my batteries and had a circuit breaker on the floor next to my seat to cut power from the battery to the alternator when the car was off. They make great high amp switches and have good solid posts, too.
Dale
Dale
Dale Shearon
68 Mustang 6394
Old 04-26-2016, 11:05 AM   #16
jamie2370
Liked 239 Times in 90 Posts
Eman...the board has all the relays and fuses built in.
jamie2370 is offline   Reply With Quote
