Old 03-27-2016, 06:38 PM   #1
David Barton
Sponsor
Default 2015 426 Hemi Drag Pak Engine
For Sale: 2015 426 Hemi Drag Pak Engine
There is nothing cheap about this engine. A lot of effort went into building it. It started as the prototype 2015 engine from SRT Dodge. It was used to develop the new 426 NA engine combination. Since then it was upgraded with new heads, valves, adjustable rockers, pistons, pins, rings, cam, pushrods, and more.
Holds the NHRA FS/B record at 8.54 @ 157 at 3250 lbs, could run 8.30's on a fast day.
-New and Improved Hemi Aluminum Block with Roller Cam Bearings and Spread Keyed Lifter Bores
-Callies Crank and Rods
-Diamond/Barton Pistons
-Titanium Valves
-T&D Individual Shaft Adjustable Rockers
-Jesel Keyed Lifters
-Trend Pushrods
-Moroso Oil Pan & Pickup
-ARP Fasteners
-ATI Balancer
-Intake comes with injectors, fuel rails and fittings
$50,000 – Includes Dyno testing and tuning. We have several EFI systems available but is not included. Will also offer track support if needed.
David Barton is offline   Reply With Quote
Old 04-01-2016, 12:33 AM   #2
budoboy
Default Re: 2015 426 Hemi Drag Pak Engine
Wish I had money for a backup engine.
-Titanium Valves
-Trend Pushrods
-ARP Fasteners
-ATI Balancer
budoboy is offline   Reply With Quote
Old 04-02-2016, 10:36 PM   #3
Jim Hanig
Liked 99 Times in 49 Posts
These is a stocker motor or comp engine.?
Old 04-04-2016, 11:40 AM   #4
David Barton
Sponsor
It's basically a Comp engine to run in Stock.
This engine would also make a great SS/GT combo.
