Old 12-07-2007, 06:55 PM   #21
bsa633
Banned
Default Re: Wow I Can Use A 3Spd
Originally Posted by Tony Janes View Post
,if it were a 69 it could run a three speed under 2007 rules.. .
yes ofcourse..but they are not the same org.class,,being able to move up one class was also a another questionable product...it changed alot when smallblocks could move up to "big block classes"...well now give em 3 speeds also..well..It WAS all about choices...some choose the 69 to get the 3 speed
but it was strange that the 2 and 3 speeds got factored at the same time in the 350 chevy case...were does that come from?...
bsa633 is offline   Reply With Quote
Old 12-07-2007, 07:50 PM   #22
JIM MEREDITH
Angry Re: Wow I Can Use A 3Spd
I threw around the 100# weight brake for the last year, most people I talked to about it agreed that would be the way to go, take weight out of the car instead of money out of your pocket, then when all this 3sp s--t, came about and I made a few phone calls and was told the whole deal was off and no changes were in the works and came home yesterday and wham, it's not in the works any longer it's a done deal. As a s/s racer on a budget, guess the new trailer is out and the new trans is in, if I can figure out how to pay for all this change over. Bracket busters will love the prices of the obsolete PG's, shifters, and the rest of the JUNK.
JIM MEREDITH 3069 SS
JIM MEREDITH is offline   Reply With Quote
Old 12-07-2007, 08:45 PM   #23
PETE PEERY
Liked 33 Times in 11 Posts
ll
PETE PEERY is offline   Reply With Quote
Old 12-07-2007, 09:32 PM   #24
PETE PEERY
For those of you who may not know this trans rule is a one way street.
If your combination was a powerglide only then you can use a 3 speed
however if your combo only came with a 3 speed you CAN NOT use a powerglide.
If we are to have a new rule it should be the same for everone or just leave it the way it was.
I have several pg's gathering dust which would be great as a spare or better yet run when
track conditions are the pits.--- but as it stands you need another $6000 3 speed for spare.
