Old 03-11-2016, 12:01 PM   #61
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Re: Heads up runs in Stock & Super Stock
These are what I found TPI Intakes and runners
The following airflow tests were performed on the University of Northwestern Ohio's SuperFlow SF600 Flow Bench.
All CFM values are corrected for airflow at 28 inches of water.
Injector flow rates are flowed at 43.5 PSI on an injector flow bench using test fluid with same density as gasoline.
AirFlow
Stock TPI/LT1 48mm Throttle Body w/o airfoil -- 783.0 cfm
Stock TPI/LT1 48mm Throttle Body w/ airfoil -- 821.9 cfm
TPI/LT1 52mm Throttle Body w/o airfoil -- 848.9 cfm
TPI/LT1 52mm Throttle Body w/ airfoil -- 898.8 cfm
Stock 98 Camaro 3800 II Throttle Body -- 554.3 cfm
Stock TPI Bosch MAF sensor w/ screens -- 517.8 cfm
Stock TPI Bosch MAF sensor w/o screens -- 658.4 cfm
Stock 87 GN 3.8L Turbo AC MAF sensor w/ screen -- 584.2 cfm
Stock 86 2.8L AC 5-wire MAF sensor w/ screen -- 576.2 cfm
Stock 96-up AC 3100 V6 MAF sensor w/ screen -- 616.4 cfm
Stock 96-up AC 3100 V6 MAF sensor w/o screen -- 670.7 cfm
Stock 94-up LT1 MAF Sensor w/o screen -- 719.0 cfm
Stock 85-87 Firebird TPI airbox mid piece -- 499.3 cfm
Stock 4.3/5.0/5.7 2bbl TBI complete -- 574.1 cfm (dry)
Stock 4.3/5.0/5.7 2bbl TBI w/o injectors -- 584.7 cfm
Stock 3800 vin L throttle body w/ screen -- 419.1 cfm
Stock 3800 vin L throttle body w/o screen -- 444.8 cfm
4bbl MPFI Holley Throttle Body -- 1287.6 cfm
Old 03-11-2016, 12:12 PM   #62
Dan Fahey
Dan Fahey's Avatar
From same web page
Flow (cfm) Max. NA HP
Stock 668 300
Stock w/airfoil 710 350
52MM w/airfoil 835 400
54MM (AS&M) 900 450
58MM 1050 500
Old 03-11-2016, 01:19 PM   #63
Dick Butler
Liked 32 Times in 19 Posts
Great info. Any track confirmation A.B.A?
Old 03-11-2016, 01:31 PM   #64
Dan Fahey
Dan Fahey's Avatar
Here is a similar website..
http://gmtuners.com/flow/
Old 03-11-2016, 01:59 PM   #65
Ed Wright
Ed Wright's Avatar
Carburetors are not rated at that high of a test pressure. Raise that, cfm goes up.
Flow a 750 cfm Holley or Quadrajet carb ar 28", it will show MUCH more than 750 cfm.
28" is for cylinder heads.
Ed Wright 4156 SS/JA
Old 03-11-2016, 03:06 PM   #66
Dan Fahey
Dan Fahey's Avatar
28" vacuum is standard = 1.01 lbf/ inch squared
Old 03-11-2016, 04:42 PM   #67
Ed Wright
Ed Wright's Avatar
It is the standard for CYLINDER HEADS! And, not all shops even use that.
When did you get your first flow bench? Over 30 years ago here.
2 & 4 barrels carbs are not even rated at the same depression.
To compare them to carburetors, they would have to be flowed at the same depression.
Old 03-11-2016, 04:42 PM   #68
Sean Cour
Sean Cour's Avatar
Liked 125 Times in 40 Posts
My cfm measurement is the timeslip! :-)
Sean Cour
T6066 ladle
Sean Cour is offline   Reply With Quote
Old 03-11-2016, 04:51 PM   #69
Ed Wright
Ed Wright's Avatar
But, we don't know as much as the office guy above. He has Google.
Old 03-11-2016, 06:58 PM   #70
Jim Caughlin
Liked 805 Times in 245 Posts
Mike, our division six director had a great idea of taking the top 10 qualifiers of stock and super stock for the year, and have a shootout. CIC rules for each round. Winner was top qualifier. I thought this idea sounded fun.
Sean,
This sounds like a lot of fun, do you think we can make this happen? I'll reinstall my rear view mirrors and get some new brake pads...
Jim Caughlin
SS 6019
Jim Caughlin is online now   Reply With Quote
