#71 |
Liked 118 Times in 41 Posts
Score! Picked up a 78 302 out of a T-bird. All the right parts and std bore. Almost done hunting down parts.
#72 |
Liked 2 Times in 2 Posts
Great RobbieRacer, now you need to get this all together for testing.Great thing with the Fox Bodies you can find parts used with a little hunting
#73 |
Got some more work done. Got the K member stripped and repainted. There must have been 10 pounds of grease on it.
Also got the motor pulled apart. This motor turned over with no problem, Not tight at all. I have never seen a crank with this much damage that didn't have a broken rod. 1/4 inch groove worn in it. WOW. |
#74 |
Liked 31 Times in 7 Posts
Wellllllllll, get it together and come race at the Vegas National !!
Rick Unterseh O/SA P/SA |
#75 |
This year will be getting it together and testing. But I plan on hitting it hard next season.
#76 |
Liked 223 Times in 73 Posts
#77 | |
#78 |
Liked 238 Times in 111 Posts
Just use it for a core on a crank kit.
Dave Noll, EF/S ,?/SA 6526 |
#79 | |
Liked 381 Times in 148 Posts
Now if it was a chev....it would of been in pieces when you found it! LOL! |
#80 |
Rear end is done. Thanks AZ Differential.
