#91 |
100 lbs. on the seat, 500 lbs. over the nose, loft enabled valve motion and hp similar to what a roller profile would provide.
#92 |
Guest
Posts: n/a
Not all the 396 375 guys are blowing up
their stuff. Sounds like the ones that are having problems should go see the engine builders of the ones that are not. Or back The rpm down below 8300 or whatever they are trying to turn them too. Changing cam profile will help valvetrain failure. I've heard of places that will run a cam and lifters on a special machine that breaks in the lifters to a new cam. Maybe that's an option, even before you run it in an expensive engine. Just a thought. If the parts are broken in properly the tool steel lifters are supposedly very reliable. I keep beating a dead horse with this suggestion, but go and test some valvetrain parts on a Spintron. Instead of lobbying for parts to cover up for a lack of understanding of what is going on in your engines valvetrain wise, try to do some research and talk to people that figure things out. If you live close to Pa go see Ray and Dave Barton. They have a Spintron machine and have worked on all kinds of engine combos. I'm sure they would be able to fix the problems you are having. Or Lane Line, Brian Tilburg, Steve Ficcaci, and Darrel Weikle are some guys that build Very fast and reliable 396 engines that last and win races. Save your money and go see any of the above people. Last edited by Todd Hoven; 01-28-2016 at 03:59 PM. |
#93 | |
No problem James, I'm good for now with my factory manifolds, and the only track it might matter not having them on is in Denver, but the way my car ran in Salt Lake City last year, I should be able to at least run the index up there, so I should be okay there too....
Gary Hampton '86 Z24,173 V6 CF/S #5824 (#78 in 2021) Last edited by GarysZ24; 01-28-2016 at 11:20 PM. |
#94 | |
Liked 26 Times in 13 Posts
Bill Harris ex 2172 STK ex 2272 S/S |
#95 |
Liked 54 Times in 27 Posts
OK, different cams have different lifts, so the springs could be something like 170 lb. seat, and 400 lb. at some average lift, like .475. As another example of "non-stock stockers" besides the 396, look at the Z28 running 9000 rpm in stock, killing every other combination for D/S.
#96 | |
Liked 231 Times in 107 Posts
#97 | |
Guest
Posts: n/a
I have an idea, why don’t we just lobby NHRA to do away with stock and put everybody into super stock? Raise the indexes or some of the slower cars can still dial in for races. That way everybody who wants roller cam’s wins. |
#98 | |
Liked 187 Times in 58 Posts
spokesman for the 1500 plus Stock Eliminator racers ,with your poor scenarios as to anything to be done about the challenges some face in Stock Eliminator ,always quick to jump on anything that is said on here to put down anything said when it comes to a much needed change from a flat tappet cam to a roller cam ,no one wins with a Attitude like yours
John Ancona 717 STK / SS |
#99 | |
Guest
Posts: n/a
I just post my opinion. I don’t agree with the roller cam movement that you and Terry support. Next, I think the 30% number is low for competitors with flat tappet cams.
I just offered a suggestion to help you guys out, that’s all. I never claimed I represented 1500. Id agree with you two, but then all three of us would be wrong. Have a nice day Quote:
#100 | |
I have said in the past on here the reasons as to why a change is needed , for my self I have been racing NHRA for 50 plus years now like many of my friends have, I still seem to be hearing the same story about flattened cams ,and ruined lifters form many along with engines that have been ruined , so it's not just two of us supporting that something be done
