Old 01-28-2016, 03:01 PM   #1
stocker396
stocker396's Avatar
Liked 58 Times in 16 Posts
Default What is the Most diverse class in stock eliminator?
Some friends and I were bench-racing and trying to figure out what the most vehiclularly diverse class is? Example: A/SA- Mostly Camaros, Novas Mustangs all big block with only a few others mixed in.
I am in E/F and you got small block Dusters and Camaros and Big Block Chevelles Buick etc.
Just curious what the make up is and how much variety there is.
Overkill is Under-rated
stocker396 is offline   Reply With Quote
Old 01-28-2016, 03:09 PM   #2
Bob Don
Bob Don's Avatar
Liked 905 Times in 193 Posts
Default Re: What is the Most diverse class in stock eliminator?
I would guess F and G. You pretty much see everything there.
Bob Don 128 SS
Old 01-28-2016, 03:21 PM   #3
Paul Wong
Liked 419 Times in 85 Posts
Just get a U Stock calendar. Until the broad based ford gift it was hard to find the same car in the class.
Paul Wong is offline   Reply With Quote
Old 01-28-2016, 04:28 PM   #4
Billy Nees
U/S no doubt about it!
Billy Nees 1188 STK, SS
Old 01-28-2016, 07:13 PM   #5
Pinballer
Pinballer's Avatar
Liked 13 Times in 7 Posts
I may be there some day...
Brian Saunders Lerna IL
'79 AMX T/SA 3790 currently being resurrected
Pinballer is offline   Reply With Quote
Old 01-28-2016, 08:57 PM   #6
joe huestis
Liked 411 Times in 114 Posts
Thumbs up Re: What is the Most diverse class in stock eliminator?
The lower classes, N through V definitely have the most unique cars. From station wagons, 4 door models, V8, V6, inline 6s, 4 cyl., turbos, etc. No cookie cutters in those classes !
Joe Huestis
Youngsville, NC
Old 01-28-2016, 09:25 PM   #7
Tim H
Tim H's Avatar
Liked 484 Times in 160 Posts
What engine puts a 78 Camaro into U/SA ?
Old 01-28-2016, 10:50 PM   #8
GarysZ24
GarysZ24's Avatar
Liked 256 Times in 103 Posts
From what I just saw, the 305 that's rated at 145hp, and factored at 180 should do it. I'm not sure about the legal weight limit for that class, but there's only three engines available for that car in that year...the 350, the 305, and the 250 inline six (which I think would make that car a V/S(A) car). Good luck if you decide to build/race that combo....
Gary Hampton
'86 Z24,173 V6
CF/S #5824 (#78 in 2021)
Old 01-28-2016, 11:14 PM   #9
joe huestis
Smile Re: What is the Most diverse class in stock eliminator?
305 - 2V rated at 180 hp @ 3770 lbs. In '78 type LT. It's in the guide.
Joe Huestis
Youngsville, NC
Old 01-29-2016, 12:58 AM   #10
Let's see ..The 302 Ford weighs about 900 lbs less..Same size engine, little bit smaller cam and carb.
Gee, I don't know..What do do ?, What to do?
