Old 12-21-2015, 10:36 AM   #11
MIKE3554
Default Re: Cleaning Radiator/?s
Amsoil has a product called Dominator Coolant Boost that has been tested for corrosion inhibitors. More info is available at amsoil.com. Data bulletin G2785.
Mike Warren 3554 IHRA V/SA
MIKE3554 is offline   Reply With Quote
Old 12-21-2015, 04:58 PM   #12
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Originally Posted by FireSale View Post
Anode is an electrical term so I looked it up to see how it related to a radiator. Seems companies like Flex a Lite make these little zinc inserts that go in the radiator drain hole. The junk in the water will eat the zinc rather than the iron or aluminum in the system. Seems to be an old heavy equipment trick. Cheap.
Sample Link: http://www.rotometals.com/product-p/...lite-anode.htm
Same thing at Summit: http://www.summitracing.com/search?S...&keyword=anode
Also try Radiator Anode on Amazon.
Dale
Hi,
When I worked at the shipyards they always welded "zincs" on the hull of ships to prevent electrolysis due to the dissimilar metals of the steel hull, brass valves and bronze screws..........
They used "zincs" as the sacrificial metal to protect the others....
Zinc is a more active metal so that it would be sacrificed and not the ship.....
If you put zinc in an engine with an aluminum intake and radiator they will be sacrificed to protect the zinc.....
A more active metal must be used for protection.....
Aluminum intakes and radiators need a magnesium anode in the coolant (water) for protection.....
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 12-21-2015, 05:46 PM   #13
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Magnesium anode source:
http://www.miatacage.com/magnesium-anode
I also found them attached to radiator caps.
BTW: My heads, intake and radiator are all aluminum on an iron block..
Learning something as I go.
Dale
Dale Shearon
68 Mustang 6394
