Old 12-17-2015, 06:03 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default wanted, 93 - 97 LT 1 engine mounts and frame mounts
For construction purposes I need some used, take off, factory stock engine mounts, both block and frame mounts.
4th Generation Camaro/Firebird with conventional LT1 block. I "think" the LT1 mounts the same as a First Generation small block
Larry Woodfin 471W
Old 12-17-2015, 08:03 PM   #2
Steve Williams
Default Re: wanted, 93 - 97 LT 1 engine mounts and frame mounts
Lt1 passenger side is different than Gen I. It is moved further back to make room for the A/C compressor. The drivers side engine mount is the same. The passenger side engine mount is different a little bit, but you can use a Gen I mount from the late 70's. If I can find the Lt1 mounts I will send them to you.
Steve Williams is offline   Reply With Quote
Old 12-18-2015, 04:17 AM   #3
Dragsinger
Thank You
Larry Woodfin 471W
Old 12-18-2015, 02:11 PM   #4
Jon Sarrett
Jon Sarrett's Avatar
Liked 140 Times in 46 Posts
V6 & V8 K-member is different too.
Jon Sarrett is offline   Reply With Quote
