Liked 5 Times in 2 Posts
This is a Cam Dynamics camshaft for a Chrysler B/RB, ground on a Crane 8620 steel billet core (that's the 689356 number). Recommended valve lash is .030" at operating temperature. Advertised duration is 318 degrees. Lobe lift is .440", resulting in a gross valve lift of .660" with the standard 1.5:1 ratio rocker arms. The .050" tappet lift duration is actually 278 degrees. Cam timing at .050" is: intake opens 35 BTDC, intake closes 63 ABDC, exhaust opens 67 BBDC, exhaust closes 31 ATDC. Lobe separation is 106 degrees, with 2 degrees of advance ground into the cam. This was a popular single 4bbl Super Stock camshaft. Information confirmed by Crane Cams which bought out Cam Dynamics some years ago.
Cam Dynamics Mechanical Roller Racing Camshaft It is a Crane 8620 Steel Billet Core Camshaft Specifications: Part No: CDR274-06 Core No: 689356 Batch No: 8A2A Advertised Duration: 318 Duration @ .050 278 Valve lift with 1.5 ratio rocker arms 0.660 Camshaft Lobe lift 0.440 Camshaft Timing @ .050: Intake Opening: 35 BTDC(Before top dead center) Intake Closing: 63 ABDC (After bottom dead center) Exhaust Opening: 67 BBDC (After bottom dead center) Exhaust Closing: 31 ATDC (After top dead center Lobe Centerline: 106 2 degees advance ground into camshaft Valve lash at operating temperature: Intake: 0.030 Exhaust: 0.030 This is one of our additional racing camshafts and is in good shape. Item is sold as is and priced to move. Please send me a message if you have any questions. $150 plus shipping for the camshaft. See ebay add below for pics: ITEM IS SOLD!
Adriel Paradise, Paradise Racing Team Driver/Crew Chief(at least my dad claims me to be) B.S. Mechanical Engineering, University of Arkansas Last edited by cutta; 12-17-2015 at 03:06 PM. |
