Old 10-25-2015, 11:00 AM   #21
Rich67stang
Liked 116 Times in 27 Posts
Default Re: SS Modified
I enjoy running modified and modified stock, you can run .300-.500 under most modified indexes with a good engine, .600 and more under and the cost factor grows exponentially. Modified cars are extremely consistent, IMO.
Richard Preiser
1613 FGT/I 1510 C/SA 161 F/DA
Rich67stang is offline   Reply With Quote
Old 10-25-2015, 11:38 AM   #22
Dick Butler
Liked 32 Times in 19 Posts
Originally Posted by FED 387 View Post
Got it thank you thought that rule only applied to SS/ modified stock cars not modified production cars--- run a balls out old comp motor and have some fun---- FED 387
And never tear down.
Old 10-25-2015, 11:46 AM   #23
FED 387
Liked 334 Times in 181 Posts
P&g. That's it
Old 10-25-2015, 12:13 PM   #24
Dick Butler
While we ran 3 SS cars at one time we were pretty well assured we had a "date" with the tear down barn where ever we raced. Part of the game but at this point I think a nice SS/CS car would be a major advantage....
Old 10-25-2015, 09:32 PM   #25
randy wilson
Liked 22 Times in 22 Posts
If they have any doubts about some mods on say SS/CS, like making sure there are no external mods in the port area, or any valves have been moved, then they will tear you basically apart. At least the top end.
don,t have one
Old 10-25-2015, 10:55 PM   #26
Dick Butler
Wish SS/CS allowed the BRODIX heads. Then it could be the cheap Mod car class and it would be a start....
Old 10-26-2015, 06:02 AM   #27
randy wilson
This. But that's too simple.
don,t have one
Old 10-26-2015, 12:42 PM   #28
Mike Mans
Liked 299 Times in 48 Posts
SS/CS is really a great class, we enjoyed running it for nearly 10 years. The challenge (like any hard run SS and GT motor) is keeping the iron heads alive. There are now 2 Dart head castings that are approved for SS/CS, which I believe have quite a bit more material in the combustion chamber and clamping surfaces in comparison to the Bowtie Vortec stuff we ran. It was really a great ET and speed to run, and no tear downs is always nice. Although Indy appears to be one of the only races these days that actually tear anyone apart anymore.
Mike Mans
Mike Mans is offline   Reply With Quote
Old 10-26-2015, 01:21 PM   #29
Dick Butler
Mike, What if NHRA made untouched Brodix Spec heads only head to run in CS?
This would be closest to lower cost entry class for SS.
Old 10-26-2015, 01:56 PM   #30
SSGT Mustang
Liked 204 Times in 54 Posts
I don't think that SS/CS would be considered either entry level or low cost.
To be in the game, the heads would need to be ported (CNC) and probably welded. You'd need a good short deck block, a custom stroke crank (probably billet), good rods (Carrillo for steel or GRP for aluminum), Jesel valve train, titanium valves, top-shelf springs, retainers, locks, lifters and pushrods, etc, etc.
Any small engine like that wants to see a lot of RPM. The parts need to be light but strong and reliable. You also need a good trans and converter program.
I looked into doing an SS/CS engine, but chose SS/BS instead based largely on availability of good used heads and valve train parts. Head porters typically prefer grinding aluminum over cast iron, and they definitely prefer to weld on aluminum.
With the comp guys selling good parts for a fraction of their original cost, it just makes more sense financially to go with a modified class that allows them (even the V6 stuff). Even with the used stuff, you're still looking at 25K to 35K to get a good engine together.
I think SS/CS is real challenge to go fast. Challenge almost always equals a lot of time and money.
Just my .02
SSGT Mustang is offline   Reply With Quote
