Old 09-28-2015, 02:32 AM   #1
CJME
CJME's Avatar
Default Rear Gear Ratio
I run a 68 camaro with an M22 trans and a 4.56 rear gear. With 28" tires i either bog the engine at launch or burn the tires off. What rear end gear do you guys recommend with this combo? i was thinking 5.38. Engine is a 12.5:1 332 and the car weighs 3000lbs.
CJME is offline   Reply With Quote
Old 09-28-2015, 12:57 PM   #2
Geerhead55
Liked 5 Times in 5 Posts
Wink Re: Rear Gear Ratio
I can only speak for myself,, but back in the day,, I ran a '66 Nova SS, that was over 3,000lbs with me in it. It had a 331/ 4-speed combo with a 10.5x 29.5 tire. I started out with 4:88s and eventually put 5:57s in it. I'd launch at 7,300- shift around the same and go through the top end at 7,600. This was with 'ol Lakewood traction bars, Moroso front springs and 90-10 shocks, as that's all we had. It pulled 'em up in 2 gears and was a fun ride! I know technology has come a long ways since the '70s, but its still basic math finding what the car likes. You've got to get it to hook first, consistently, before you start playing anymore. Put a good slick under it and work your suspension.Good luck with your project.
Danny Durham
Old 10-15-2015, 10:19 PM   #3
CJME
CJME's Avatar
Default Re: Rear Gear Ratio
I run MT 28/11.5/15 ET streets and i'm soon changing to Hoosier slicks 28/10.5/15. The 2.20 first gear of the M22 is killing my 60 ft. There are two options i'm considering: Changing trans to a 2.88 first gear or change rear end gears. Which do you guys recommend from experience?
Old 10-16-2015, 11:56 AM   #4
Jeff Stout
Liked 706 Times in 283 Posts
My old 70 Chevelle with 355 had 5.13 and 2.88 first with 50 lb flywheel. I would leave at 4000 and it would hook very well and not bog but drive through first pretty good. This was back in 1995 so Im sure its not whats best today
Old 10-16-2015, 12:36 PM   #5
Mike Pearson
Mike Pearson's Avatar
Liked 1,948 Times in 589 Posts
You will only get a handful of runs with that Muncie once you put a lower gear in the rear. I would put a 5.57 to start with. Put a Jerico trans with a 3.10 low gear. Also you want a light flywheel. I ran a 14 lb. wheel in my car years back. it was much faster than the 25 lb. wheel. With a stick car you want some wheel spin to keep the RPM up and the breakage down.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 10-18-2015, 05:30 PM   #6
tj310
In our 305 J/S it's gone quicker every time I've put more rear gear to it , 6.0 now .. A good trans ( Liberty ,G force , Jerico ) and a slipper clutch will save money and aggravation in the long run. ---Trevor
