Old 08-03-2015, 06:17 PM   #1
Monte Howard
Monte Howard's Avatar
Liked 71 Times in 23 Posts
Default BBC Heads 3872702
I took these off a engine that only has around 600 miles on a rebuild. Virgin castings for a stocker build, or correct heads for 1966 396/427 resto. I am asking $850. Plus shipping. sska31@gmail.com
Monte Howard 3209 STK, 3208 SS
Monte Howard is offline   Reply With Quote
Old 08-03-2015, 06:51 PM   #2
63corvette
Liked 362 Times in 105 Posts
Default Re: BBC Heads 3872702
What are the casting dates?
Thanks
63corvette is offline   Reply With Quote
Old 08-03-2015, 10:05 PM   #3
Monte Howard
B22 6
Old 08-04-2015, 07:44 AM   #4
Liked 11,011 Times in 2,263 Posts
Where is the casting date on a four bolt main 396 block?
Old 08-04-2015, 09:05 AM   #5
Jim Cimarolli
Liked 166 Times in 46 Posts
Smile Re: BBC Heads 3872702
Larry, the early blocks had the casting date just above the oil pan rail on the right side.
Jim Cimarolli is offline   Reply With Quote
Old 08-04-2015, 10:06 AM   #6
8secchevelle
Liked 6 Times in 2 Posts
Early block casting date was on passenger side above pan rail later blocks had it on the bellhousing flange
8secchevelle is offline   Reply With Quote
