#501 | |
Liked 33 Times in 16 Posts
The set-up as run... ![]() Just grasping at straws here. I did not have any 10 gauge wire on hand so I paralleled two 12 gauge wires to the battery positive and a short 10 gauge ground from the alternator case to a head. Edit: Just re-read the instructions and it states no Jegs alternators are designed to to be spun beyond 15,000rpm (6000 engine rpm). ![]()
Rich Taylor I/SA - 321 Last edited by HandOverFist; 05-30-2015 at 01:48 AM. |
#502 | |
Liked 320 Times in 102 Posts
I think that you have it backwards.... Big crank pulley & small alternator pulley = overdrive Small crank pulley & large alternator pulley = under-drive 4" crank pulley with 2" alt pulley at 7,000 rpm engine RPM = 14,000 alternator RPM 2" crank pulley with 4" alt pulley at 7,000 rpm engine RPM = 3,500 alternator RPM Hope this makes sense to you and helps...... Bob
#503 |
Liked 61 Times in 25 Posts
As stated above, the small crank pulley slows it down.
#504 |
You know, that is what I thought as well but I let someone talk me into that one lol. With that out of the way I can see no reason for two failures in a row other than these alternators are junk.
Rich Taylor I/SA - 321 |
#505 | |
Liked 237 Times in 126 Posts
Dale
#506 |
Liked 6 Times in 6 Posts
Rich a one wire alt. has to turn around 2000 rpm to excite it for it to start charging. Once it starts charging it stays until you shut off the engine
Joe |
#507 | |
#508 |
Liked 275 Times in 76 Posts
Bob is right on. That crank pulley has to be close to 3.5", if the alt pulley is 2", that calculates to 12,250 at 7000 RPM. At 1000 RPM the alt is only at 1750 RPM.
Will the alt produce any voltage if you increase the engine RPM to 2000 or 3000? Sean
#509 |
From the beginning both alternators worked fine, even at idle. I guess they lasted part of one stint each at the track when I realized they were no longer charging. You can wing it to six grand if you like...it aint happening. Something inside the alternator is just not holding up it's end of the bargain.
#510 |
Liked 799 Times in 236 Posts
Just went through a similar issue. The one wire alternator didn't excite until 2500 alternator rpm. With the combination of a large alternator pulley and small crank pulley, there wasn't a lot of time that the alternator was putting anything back into the battery. To make things worse, the alternator had a bad diode and rectifier so it was only putting out 15 amps when it was charging.
![]() Changed the charging system to a larger 74 amp constant output alternator with a 6" crank pulley. The excite power wire runs through a heavy duty toggle switch on the dash so the alternator can be turned off during a run. -Al
"That'll never work....." |
