#461 |
Liked 33 Times in 16 Posts
Its a Dynamic C4 with a 2.90 gearset. Convertor is a Dynamic Race 8 with mech diode.
Rich Taylor I/SA - 321 |
#462 |
Liked 799 Times in 236 Posts
Rich, driveshafts can bind if the u-joints 'break' out of phase..... -Al
"That'll never work....." Last edited by Alan Nyhus; 05-11-2015 at 09:55 AM. |
#463 |
But that bind would exist regardless of rotation direction, right?
#464 |
I would think so, Rich. May be worth it to change the pinion angle at the front (both ways) and see if the binding gets better/worse.
"That'll never work....." |
#465 |
When I had the drive shaft loose from the pinion and holding it aligned with the front the resistance was felt rotating only in one direction and was constant...about half as much the other direction. Not near as free as the Camaro/metric trans for sure. I'll admit I may be ghost hunting here hehe.
#466 |
Liked 204 Times in 54 Posts
Call Dynamic. Band adjustment, maybe?
#467 |
Liked 160 Times in 51 Posts
C-4 output shaft turning effort higher in one direction than the other is normal.. there is less turning effort when the rear one way roller is overrunning..... higher effort when the rollers are holding and the gear sets are turning.
Brian Thompson NHRA Stock / Super Stock Class P/SA 6665 SS/MA 6665 |
#468 |
Liked 21 Times in 13 Posts
The AODE that I re-built acted the same way. good job so far Rich.
Brian Carpenter Stock 1358 |
#469 |
Rich,
Lean that tune up to around 13-13.2 and watch it pick up a ton!
#470 | |
After Alan brought up the drive shaft phasing I began to doubt myself and took a look at it again today...all looks good as far as I can tell. I'll re-check pinion angles again. Car is on a lift with the rear fully extended in the pics, thus the extreme angle at the pinion. ![]() ![]() Junk shots under the car... ![]() ![]() ![]() ![]() Had some popping going on at cold start initially...figured it was lean at idle and WB confirmed. Gave it a little more fuel at that point and calmed it down. I'm wondering if I should just remove the piggyback for now and let the wideband O2 sensor tell me what to do via fuel pressure adjustment.
Rich Taylor I/SA - 321 Last edited by HandOverFist; 05-12-2015 at 01:43 AM. |
