ANybody else have a hard time getting the right fluid level/reading on your lokar dipstick? This is the one that has the nut inside the pan. It seems like the tube is small and the end of the checker is big and all you do is drag fluid from the sides of the tube that you just put in and you get a full/over full reading when you know its not... I figure it will check it again after it has set and then you're only good for one attempt...hehe
1968 Bird/TRW 455/Home ported 13's, '70 Qjet,Holley Street Dominator manifold, Comp Solid FT, 10.817/122.30/1.440 Workin' on E/SA combo ![]() |
Liked 6 Times in 4 Posts
They (Lokar dip sticks) are kind of a pain in the rear
to read. |
Liked 33 Times in 16 Posts
Never tried one Brent...any help maybe to roughen up the end of the stick with some sandpaper or such?
Rich Taylor I/SA - 321 |
Liked 237 Times in 126 Posts
Liked 539 Times in 112 Posts
They are a bit of pain to read. After adding fluid, I usually hop in the car and drop it in gear a couple of times, then hop out and re-check it, looking at both sides of the stick. By then, you can typically read it more easily.
Jim Kaekel 3836 STK |
Yea, same here... one second, nothing, then add a quart
and it looks overfilled... I do the same , put in gear and recheck.... you just can't recheck after you've added... I'm thinkin the end needs to be ground off, so it won't retain so much.fluid... if i.could find.correct dipstick.for the.car, i.would probably. go back...thought this would ease Trans removal/swaps...I always check.both sides of the stick, too
1968 Bird/TRW 455/Home ported 13's, '70 Qjet,Holley Street Dominator manifold, Comp Solid FT, 10.817/122.30/1.440 Workin' on E/SA combo ![]() Last edited by brent flynn; 03-31-2015 at 03:13 PM. |
If you have a tube/stick that fits maybe you could just get one of these plugs for when finished level check... http://www.jegs.com/i/ATI/085/973081...78#moreDetails
Be aware that any aftermarket stick and tube can read improperly. However in my experience Lokar is hard to fill and usually not reporting the correct depth of fluid.
I like to verify the depth with the pan off. The full line Hot should Not be above the pan rail. |
Liked 254 Times in 78 Posts
I have trouble reading the Lokar also. I run a metric 200, seems to be fine at current level, but just curious how might the trans act if it is somewhat over filled?
Mike Moller NHRA 203 Q-R-T/SA |
#10 | |
I 'll figure it out...hehe
