Old 11-06-2007, 10:24 PM   #1
40Coupe
Default Wheelie Pic
The car is starting to leave better.
40Coupe is offline   Reply With Quote
Old 11-06-2007, 10:38 PM   #2
L79racer
L79racer's Avatar
Default Re: Wheelie Pic
Looks great. What combo do you have in it? Motor, tranny and rear gear?
L79racer is offline   Reply With Quote
Old 11-06-2007, 11:27 PM   #3
40Coupe
Well it certainly isn't stock legal!
3525 lbs
468
13:1
AFR 305's
Vic Jr.
HP 1000
2" Hookers
GZ pump
TH-400
ATI Treemaster 5800 flash
4.30's
Hoosier 30 x 9 radials
Launch at 1500, shift light comes on at 6300/6800 stripe at 7300.
Best
1.340
3.96
6.18 @ 110.79
8.10
9.73 @ 137.44
Old 11-10-2007, 04:36 PM   #4
67camaroracer
67camaroracer's Avatar
Man it looks good. I tried 2" headers on my 427 BBC and it killed the torque. I have the same car, same rear set up small tire turbo 350 and gone 9.89et 1.37 60' but don't look that good. What kind of conditions are you running in? I bet you have more et there. I went 9.89 at 133
You must have 725 horse I'm guessing.
67camaroracer is offline   Reply With Quote
Old 11-14-2007, 12:34 AM   #5
40Coupe
That pass was off the trailer right before the ring gear broke! On the next pass I heard a noise in the rear on the shutdown and decided to load up. I found several broken teeth on the ring gear the next day. I just finished buttoning it back up with a new 4.33 Pro Gear. I'm certain the car will go into the .60's under similar conditions. The DA was 213' that day.
Last year with 1 7/8" headers it went a 9.83 @ 136.01, 1.349 60 foot with a strong tail wind in 850' DA.
Old 11-14-2007, 05:51 PM   #6
67camaroracer
Pretty good conditions compared to Lebanon Valley Dragway where i run. Still can't figure out how your running such a small primary tube. It must be the difference between the AFR exhaust port and the Merlin exhaust port.
