Old 03-16-2015, 01:37 AM   #291
SSGT Mustang
Liked 204 Times in 54 Posts
Default Re: Ford vs Chevy Build-up
Originally Posted by HandOverFist View Post
Yes, something else I will need to run down. Ebay would likely be a good place to begin, right?
This plate look correct? http://www.ebay.com/itm/MAVERICK-MUS...42f379&vxp=mtr
Or maybe this? http://www.ebay.com/itm/Ford-289-302...ddd3ca&vxp=mtr
That first one is for a stick, not an automatic. And that starter plate is pointless (it's for starting an engine on a stand, which I would never do). Get the steel one from the guy in the link I provided.
SSGT Mustang is offline   Reply With Quote
Old 03-16-2015, 01:41 AM   #292
SSGT Mustang
ATI is who I was looking to for a convertor. They want $295 for their 157T flexplate. I'm going to call Brian Thompson and get the skinny since he uses ATI in his cars.
Rich, you're killing me, man. I've got to go to work in 5 hours.
TCI, not ATI.
http://www.summitracing.com/parts/tci-529610
Signing off....
Old 03-16-2015, 01:48 AM   #293
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
I'm talking ATI convertors lol...
Rich Taylor
I/SA - 321
Old 03-16-2015, 10:49 AM   #294
west coast
Liked 230 Times in 75 Posts
On the flex plate make sure you have the right size bolt circle pattern to match your converter.
James Boyce 6052 K/SA Stock
National record holder 2015,2018,2 times in 2022,2023
west coast is offline   Reply With Quote
Old 03-16-2015, 11:03 AM   #295
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
The block plate on my Ford Racing 302 for GT/MA is one of the multi-fit deals. Looks like this:
http://www.summitracing.com/parts/pma-pa26445/overview/
I have a TCI trans and flex plate that haven't seen the track yet. The flex plate (157 tooth) looks nice and strong but I had a lot of quality control issues with the C4. The case wouldn't fit the transbrake solenoid they sold me (push in solenoid, threaded case) and the piston in the foreword shift solenoid had a huge chip in it. I replaced the whole shift solenoid with a Performance Auto unit. The pan provided with it wasn't a flush fit and leaked like a sive. Had to replace that with a Moroso pan. For these reasons they won't be getting any future business from me.
PA and others sell "heavy duty" pump gaskets. They are worth the extra buck or two. $20, actually.
I put an SFI bell housing on my motor and have a new stock 157 tooth one here I don't need. Send me a PM if you're interested. Shipping+cheap...
Dale
Old 03-16-2015, 12:48 PM   #296
HandOverFist
James - Most of the 157T flexplates sport a 10-1/2" bolt pattern, right? Seems I have seen some of the Ford convertors that use studs instead of the usual pads for attachment...guess I will just have to wait and see.
Dale - I'll be in touch about that bellhousing. Thanks! I too was kind of leary about some of the transmission builders out there...I would have preferred Arnett did one for me. Did a lot of research and questioning before giving Dynamic Transmission the go ahead.
Rich Taylor
I/SA - 321
Old 03-16-2015, 03:31 PM   #297
west coast
Yes 10 1/2' is correct.
Old 03-16-2015, 04:55 PM   #298
Tony Corley
Liked 61 Times in 25 Posts
Bell and mount should arrive on Weds.
Tony Corley is offline   Reply With Quote
Old 03-17-2015, 03:30 AM   #299
HandOverFist
Oh joy...not enough clearance between the balancer and the pump outlet for a hose. Stock balancer was 6.250" diameter where the new one is 6.5". This Ford is going to kill me before I figure it all out. Found a SFI Pioneer balancer 6.1" that should solve the problem...same 50 oz balance so it should not affect the engine balance.
Anyway, I have the balancer, flexplate, transmission and alternator on the way. The only remaining item is the torque convertor.
Rich Taylor
I/SA - 321
Old 03-17-2015, 08:10 AM   #300
Tony Corley
I would also change to a much smaller crank pulley.
