Old 02-15-2015, 06:20 PM   #11
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: Master Cly Install Help
Tom - Don't know about Lamb, but Strange recommends using the rear port to the brakes which require the most volume. Using four-pistons front and rear on ours I just plumbed as usual with the rear port serving the rear system and used a 2lb residual valve in that line.
Rich Taylor
I/SA - 321
Old 02-15-2015, 07:03 PM   #12
Tom Meyer
Liked 354 Times in 120 Posts
I will check with Lamb on Monday, this is turning into a real search to find fittings to get this to work and look nice. Spent most of the day looking for stuff when I could have been working on the car. Like I said before it worked fine with the stock master cly and now I try and make it better and struggle big time. Thanks to all Tom
Tom Meyer 5240 SS Stock ???
Old 02-15-2015, 09:10 PM   #13
Alan Nyhus
Liked 800 Times in 237 Posts
Tom, the Dorman number for a 1/2"X20 nut for 3/16" tubing is 490-302. For 1/2"X20 1/4" tubing it's 490-305. In the link I posted earlier they are refered to as 'Oversize Tub Nuts'. The 'oversize' refers to the fact that the nut is larger than the normal brake line nuts for a specific tubing size. -Al
"That'll never work....."
Old 02-15-2015, 09:25 PM   #14
Run to Rund
Liked 56 Times in 29 Posts
I found some short lines with the big nuts on one end, and regular line nuts on the other. Pep Boys had various such lines.
Old 02-16-2015, 02:25 AM   #15
GTX JOHN
80s Dodge full size PU havr them
The Cylinder I use is proportioned 69 Front and 31 Back
John Irving
741 Stock
741 Super Stock
Old 02-16-2015, 08:16 PM   #16
ss wannabee
Liked 7 Times in 7 Posts
Would the BR-150 and BR-155 tubing nuts from the SUR & R company be the ones
Tom is looking for? If so, available from some auto parts stores...as well as Summit
Racing.
ss wannabee is offline   Reply With Quote
Old 02-16-2015, 09:55 PM   #17
Tom Meyer
Got it covered today with a call to Roger Lamb [great people] but he did have to go dig for them. Also on my app rear line goes to front brakes front line to the rear. I want to thank every one for your help. Tom
Old 02-16-2015, 11:27 PM   #18
Paul Merolla
Paul Merolla's Avatar
Liked 293 Times in 65 Posts
Tom, does this mean we'll see you out this year?
Paul Merolla is online now   Reply With Quote
Old 02-17-2015, 05:52 PM   #19
sugar1366
Napa/Gates Part #G49504-0303 adapts 9/16-20 to 3/16 female inverted flare.
I know you got it solved already, but thought I would put the info out there for future reference.
Eddie Bolton
sugar1366 is offline   Reply With Quote
