Liked 335 Times in 182 Posts
In a 80 Olds Cutlass what is "the best" engine killer combination for J/SA ?? Chevy or Olds and which engine to be a virtual record setting combination?? FED 387
#2 | |
However, you will need to change the grill to the 442 version with square headlights unless the car is a 442 model already. |
Liked 999 Times in 202 Posts
I have a real nice solid 1980 buick regal limited for sale.Would make a great stocker and can use the olds ,and chevrolet engines.
#4 | |
Liked 14 Times in 10 Posts
I'm not really sold on the reliability of the 77-80 Olds 350 engine either. The cylinder head castings are lightweights and notorious for cracking as well as the "windowed" lightweight blocks for failing. An earlier year block can be substituted but the head bolts are a different diameter and modifications have to be made. On the other hand, Don Forester always ran very well with the Olds 350 and in a variety of body styles to boot. I think it could be made to work, just not easily. That, however, can make the potential reward all the more gratifying! Last edited by Rick Schilling; 01-13-2015 at 01:40 PM. |
Liked 56 Times in 27 Posts
FED 387,
I would say the best combo for the money is the 305ci Chevy @ 235HP vs the Olds 307ci @ 250HP... Check it out on Dwight Southland Class Racer site, gives you all the answers... Good Luck & Welcome !!!
Dave Ribeiro 1033 STK |
With a 1980 Olds you can run the Olds 350 which will be all over the Chevy 305 and Olds 307.
258 hp vs 275
.474 lift vs .400 800 cfm vs 750 What was the question again?
