Old 12-25-2014, 12:18 AM   #11
Dinsdale
Dinsdale's Avatar
Liked 6 Times in 2 Posts
Default Re: I Accidentally went too fast !!
Originally Posted by Jim Bailey View Post
You guys are a bunch of comedians!.... I wonder how you'd feel if it was YOU I beat, in a double breakout, when I went 9.999? - lol - .....I guess it's OK, I'd promise not to do it again.
If your opponent protested that you weren't legal to run a 9, then you'd get tossed and he'd be back in. If no track official notices or no one says anything then you are off to the next round.
If this was qualifying, a verbal warning is normal and second offence you get it in writing and are going home. If you really piss someone off then blacklisted from all your division tracks is also possible.
Dale Posnick
Dinsdale is offline   Reply With Quote
Old 12-25-2014, 01:09 AM   #12
topspeed632
add weight
topspeed632 is offline   Reply With Quote
Old 12-25-2014, 12:52 PM   #13
SSGN
SSGN's Avatar
Liked 202 Times in 52 Posts
Thumbs up Re: I Accidentally went too fast !!
I think I would just enjoy the car going faster
Kevin
The more people I meet the more I like my dog
Kevin
Old 12-26-2014, 10:13 AM   #14
C and W Racing
C and W Racing's Avatar
Liked 13 Times in 3 Posts
It looks to me like if your car could accidentally dip into the 9's, then it should already be running very low 10's which means in the right circumstance it has the potential to run in the 9's. So knowing that, you should really have the car certified for that as well as the driver should have all the proper gear in case that were to happen
Chuck
C and W Racing is offline   Reply With Quote
Old 12-26-2014, 11:11 AM   #15
Ed Wright
Ed Wright's Avatar
Protesting somebody that went 9.99 without the window net up, or multi-layer suit on would be a chickens**t deal.
Ed Wright 4156 SS/JA
Old 12-26-2014, 01:26 PM   #16
Dan Wilson
Originally Posted by topspeed632 View Post
add weight
This is the correct answer. Find out how much the car slows using 10 lb adjustments. Or use 1 gallon fuel adjustments.
Dan
Dan Wilson, STK3171, K/SA
Dan Wilson is offline   Reply With Quote
Old 12-27-2014, 08:13 PM   #17
prixmoracing
In time trials we give 1 warning to slow it then 2nd would be go home. Qualifying pass would be DQ.In eliminations a breakout under a legal et would be ok as long as the dial is a "legal" dial.
Unfortunately those with the least amount of common sense are completely unaware of their situation....
prixmoracing is offline   Reply With Quote
Old 12-27-2014, 08:36 PM   #18
Ed Wright
Ed Wright's Avatar
Who is "we"?
Old 12-27-2014, 08:50 PM   #19
Ron Ortiz
Ron Ortiz's Avatar
Liked 317 Times in 103 Posts
Jim, I think you should be flogged at midnight the week prior to the infraction.
Ron Ortiz
U/SA enough of this blatantlessness.
Ron Ortiz 2102 STK
Ron Ortiz is offline   Reply With Quote
Old 12-28-2014, 12:28 PM   #20
prixmoracing
Who is "we"?
Tech Dept. Brainerd International Raceway (BIR) .
