Old 12-18-2014, 12:15 AM   #1
Jeff Goss
Jeff Goss's Avatar
Default Tech question 64 Chevelle Wagon
So, I am getting my 64 Chevelle 300 Deluxe 4 door Wagon Super Stocker repainted.
The trim that runs through the fender, doors and quarters is bent and damaged-I think beyond repair.
This trim seems to be made of something called "unobtainium". Lol! I cannot find any good pieces anywhere.
Question is, can I delete this trim and just weld the holes up? Would Tech have a problem with it? I can put the trim back on, but it is so bad.
Opinions?
Thanks very much!
Jeff Goss is offline   Reply With Quote
Old 12-18-2014, 12:18 AM   #2
Dion Hildebrandt
Dion Hildebrandt's Avatar
Default Re: Tech question 64 Chevelle Wagon
get it repaired, or use what you have and keep an eye out for better pieces.
Dion Hildebrandt 6009 STK H/SA
Dion Hildebrandt is offline   Reply With Quote
Old 12-18-2014, 01:49 AM   #3
Liked 5,145 Times in 1,964 Posts
You can remove that trim if you want to.
Believe me...Nobody cares.
Some of those wagons didn't have it anyway..
Do you plan on welding up the holes yourself?
Be careful. You could cause yourself a whole lot of trouble with the bodywork.
Old 12-18-2014, 11:04 AM   #4
njk53
Are the trim pieces stainless or anodized aluminum? Don't throw them away. There are guys out there that can work miracles with restoring trim pieces. I believe the stainless pieces are easier to bump out and re-finish Also, try Desert Valley Auto Parts in North Phoenix AZ. to see if they can help you with replacement trim pieces.
I at one time had a 64 2 door Chevelle Wagon with a 283 with a 4bbl carb and a powerglide. Man I'd like to have that one back. Would have made a great stocker.
Nelson Kowal
Stock 345
Old 12-18-2014, 11:19 AM   #5
Jeff Goss
Jeff Goss's Avatar
Thanks everyone!
I believe these are aluminum. I would really hate to put these ugly pieces onto a new paint job. I would like the cleaner look without the trim I think.
The body man would be welding the holes.
Just weighing my options at the point.
Old 12-18-2014, 11:37 AM   #6
Lyn Smith
Liked 997 Times in 201 Posts
Welding up all the holes you have will be a real pain.Join a Chevelle club site and put up a want ad for your moldings,or find some that are reproduced,and adapt them to your car.A 68-72 Nova molding would be a example of that.I have some impala moldings that you might be able to adapt to your car.
Old 12-18-2014, 11:57 AM   #7
Jeff Stout
Liked 706 Times in 283 Posts
May not be a great answer but you could straighten the trim and paint same color. May look ok.
Old 12-18-2014, 12:16 PM   #8
Daran Summerton
Daran Summerton's Avatar
Liked 66 Times in 37 Posts
Another option is peel and stick molding that matches trim. I did it on a 66 and looked perfect!
72 cutlass
Daran Summerton is offline   Reply With Quote
Old 12-18-2014, 12:25 PM   #9
Jeff Goss
Jeff Goss's Avatar
Who can do the straightening and polishing?
Not sure how much that would cost, but it might be a wash with the labor cost involved in welding the 20 holes up.
Thanks for all the comments!
Old 12-18-2014, 12:47 PM   #10
Dion Hildebrandt
You should be able to find someone locally that can do the trim repair, if not I use a guy up here in Calgary that does a fantastic job of it.
and you are correct it will be a wash one way or the other, which is why I suggested looking for replacement pieces, up on Vancouver island is a place called "Tin man autowrecking" and he has almost always had whatever difficult piece I have been looking for.
