Liked 36 Times in 11 Posts
Is there a measureable advantage for aluminum over steel driveshaft? Is one more durable? This is a SS car.
Liked 808 Times in 247 Posts
I ran a back to back test when I swapped over, steel driveshaft weighed 16#, alum was 13#. Zero performance improvement.
Jim Caughlin SS 6019 |
Maybe 1/2 a tenth max in my car , steel is more durable , if something rubs on aluminum it's gonna break.---Trevor
I've had both Indy car, saw nothing.
Ed Wright 4156 SS/JA |
Liked 99 Times in 60 Posts
No performance difference between the two seems reasonable considering the rotating radius is very small.
This seems to me a good part to slightly lower cost of a build up without any downside in performance.
Larry Woodfin 471W |
Liked 9 Times in 8 Posts
Its a function of rate of acceleration and rpm.
If you spin your stuff to 9-10,000 rpm aluminum or carbon might be for you, but you must have the total package to see any measurable gains, lightweight clutch, flywheel, axles, spool, ect....anything that spins. If you have a 5 or 6' long shaft, aluminum or carbon might be for you. BUT.....with that being said, if you have a converter full of fluid that spins (like what's in a mini van) save ur money, as there is too much slippin'/slidin' and torque multiplication and weight going around to make most lightweight driveline components worthless. I would have Carbon in mine if the rules allowed it ![]() Last edited by Bill Diehl; 12-03-2014 at 01:41 PM. |
Liked 71 Times in 38 Posts
I've had both steel and aluminum in my car also, with no noticeable improvement. An aluminum driveshaft looks cool, but I think it's one of those things that in theory makes a lot of sense, but in practice really doesn't make any difference.
Liked 56 Times in 29 Posts
There have been several heated threads on yellow bullet; if there is any consensus, it is that the e.t. improvement is slight. I think the bigger point is the critical speed of the shaft, which is a function of length, diameter, and material.
Same issue with lightweight rearend parts, gundrilled axles, alum spool, lightened ring gear, no noticable improvement. On the other hand, lighter weight flywheel and clutch made a huge difference. In my case, this is a 4 cyl motor that crosses the finish line at 9200.
Some good reading on the subject:
http://www.dragzine.com/tech-stories...for-your-ride/ http://markwilliams.com/driveshafttech.aspx |
