Old 11-06-2014, 09:01 PM   #21
Nick Heath
Liked 576 Times in 137 Posts
Default Re: Indexes for New Classes
Originally Posted by deuces wild View Post
Just asking so don't go off on me. Can say a 2008 put a 2014 engine in and just change the front and back a be a 2014? I saw where SAM swapped out the front and back to make a newer model with their Copo.
I could be wrong but I don't believe so. 2010s, 2012s and 2013s can become 2014s fairly easily. Some have done this already - Bo Butner's white CJ has been updated a few times. However I'm thinking that 2008s are stuck as 2008s.
Old 11-06-2014, 09:36 PM   #22
Rat Raceway
Rat Raceway's Avatar
Liked 35 Times in 17 Posts
Send a message via MSN to Rat Raceway
The COPO 427 and the factory shootout engine are so far apart it's not even funny. The factory shootout engine also gets a 30lbs weight break on the normal engine. From what I heard new Challenger 426 is the same, not even close to there factory shootout engine. Makes no sense.
If they don't make a separate classes for them I know of a few racers that will not be racing NHRA.
Ross Gregory
5133 Stock,Super Stock
53 Top Dragster
Rat Raceway is offline   Reply With Quote
Old 11-06-2014, 10:51 PM   #23
D.Johns
D.Johns's Avatar
Liked 18 Times in 6 Posts
That is correct. Everything changed. The only things that remained the same was the front windshield and the roof line on the 05-09 Mustang and the 2010-14. Even the quarter windows changed in size. Actually even the floor pan changed. There was also another revision to the floor pan in 2013 IIRC.
2014 Cobra Jet FS/XX #3345 STK/SS
Like us on http://www.facebook.com/pages/Daniel...25886327426822
D.Johns is offline   Reply With Quote
Old 11-06-2014, 11:08 PM   #24
D.Johns
D.Johns's Avatar
Originally Posted by Andrew Hill View Post
Easy there, no need for the name calling. As usual? Please educate me if you think I don't know what I'm talking about. Obviously the 2.3L blower won't make as much as the 2.9L, but Fezell has been 8.50 (yes at a much lighter weight), quicker than any Coyote has been so far. I think "no where close" is a pretty big exaggeration.
Also, since the FS classes are now weight/hp based, will he not have a 38 hp x 6 lb/hp = 8 lb break against the 2014s?
08 auto/Stick 505/498
13 auto/stick 531/500
14 auto/stick 543/525
The 13 coyote(5.0/2.9) makes 100-150hp more then the 5.4/2.3 in the 08. The 2014 uses a smaller blower pulley. The 5.0 has more RPM capability which is where the Ford Modular engines make their power. The 13 stick has about 2tenths advantage over the 08 stick. The 13 auto has a tenth advantage. The stick combinations in the 13/14 will start getting HP bumps though once some of them are built.
Old 11-07-2014, 04:35 AM   #25
Adger Smith
Liked 880 Times in 311 Posts
If all the other brands are like the 426 Mopar shootout heads that were dropped at my shop there is some Bad A** stuff out there!!
Adger Smith (Former SS)
Old 11-07-2014, 10:47 AM   #26
Troy Henderson
Troy Henderson's Avatar
Liked 130 Times in 42 Posts
I'm still waiting on GT stock so I can drop a Hi-Ram 396 LS in my old iron
Troy Henderson
Henderson Race Shop LLC 816-520-5389
www.hendersonraceshop.com
Troy Henderson is offline   Reply With Quote
Old 11-07-2014, 09:12 PM   #27
Sonny Stancil
Smile Re: Indexes for New Classes
Some people will like the new indexes some want all fuel injected cars should be in the new classes have the old base classes for carb cars
Sonny Stancil is offline   Reply With Quote
