Call Mike Gardner @ 703 675 4479 - Cash and carry preferred!
Used Race Equipment Sale (some New) Call Mike G @ 703 675 4479 Used #7530 MSD Digital 7 $400.00 Jegs Low Pressure tire gauge $120.00 (was $239.00 new) Moroso 60lb Tire Gauge $20.00 each 3 #68815 Moroso Oil Tank Breather $8.00 each 2 Sets Front Brake Pads Lamb, WIlwood, or JFZ??? $10.00 set 3 CO2 Bottles 10ounce $40.00 each SOLD SOLD SOLD 2 CO2 Bottle roll bar bracket $10.00 each 5 LB Nitrogen Bottle w/ Regulator and special valve for filling gas shocks $50.00 ARP Flexplate Bolts #100-2901 $ 5.00 Moroso Flexplate Bolts #38760 $ 5.00 New Aeromotive Fuel Filter canister and used filament filter $20.00 Large amount of new and used AN fittings Call Large amount of mostly used AN Braided Line assorted sizes Call Holley assorted Jet box $40.00 S&W Dzus Repair Kit box $40.00 Assorted Dzus (3 bags) $10.00 each bag Moroso Radiator Cap 23-25LB $5.00 Bag of Numerous Converter bolts $15.00 Bag of Beadlock Bolts $5.00 Bag of Header bolts $5.00 Dynatech Header Collector Tab Kit $5.00 Moroso #64923 Throttle Return kit $15.00 2 Moroso #8800 Vibration Mount Sets $5.00 each Percys Exhaust Gas Temperature Probe, New, never used $25.00 Turbo 350 Fresh, Built by Turbo Flite (Leon Mirinian) for Stock Eliminator Standard shift pattern $700.00 Joe Scott Quadrajet #17066553 $400.00 305 block, crank and heads w/ assorted parts. No Pistons, Rods or valve train. Was Spare stocker engine $700.00 Converters: ATI A4240306 1 8” Stocker Conv. $400.00 ATI A3903502 4 9” Pro Tree set up for 598 S/G for reaction and top end charge $500.00 ATI A3915905 4 9” 632ci T/S car set up to loosest $500.00 ATI A3803204 4 medium tight 10” converter fuel and blown 408420 good for strong 632 in dragster 1200+hp $500.00 ATI A3903601 4 tight 9” 408930 fuel and blown converter $500.00 ATI A3803206 2 tight 10” fuel and blown 408420 top dragster type 632+ big NOS $500.00 8 10LB NOS Nitrous Bottles Filled to 24 LBS – WILL NOT SHIP $200.00 each Strange Aluminum 9” Center Section .410 Gear, 40 Spline Used w/ case $850.00 SOLD SOLD SOLD CVR Big Block Chevy Water Pump Never could get fitting to seal in pump $75.00 Numerous CSR & East Coast Starters Used $75.00 each Big Block Chevy Koni Electric Shocks, Never installed on car Shock #8246 1044SPA2 Controller #1290001 $1200.00 I have a lot of new in package Big Block and Small Block Chevy gaskets make offer. 8 used cams, mostly big block Chevy $75.00 each Alot of 25LB shot bags, weight bars Make offer/ will not ship Turbo 350 case w/ older JW Ultra Bell Make Offer Trans Brake Buttons new and used $60.00 for the lot Moroso cool can, never used $50.00 Box of Dominator spacers, gaskets and a HVH 2" Super Sucker $60.00 More to added later. Last edited by Mike Gardner; 10-18-2014 at 12:30 PM. |
Liked 121 Times in 11 Posts
You have PM
Joe DeMarzo 1317 STK |
Interested in mad handheld, car low pressure gauges and jet tuning kit. Jim 563-505-0293 jimschaechter@earthlink.net
James Schaechter 3163 STK |
Liked 166 Times in 71 Posts
Is the stocker converter for small or big block application?
Chris Chapman 1969 Chevelle NHRA F-G/SA 1090 |
Liked 53 Times in 25 Posts
You have a PM.
Dennis P Chapman 1904 STK NHRA National Record Holder Car Owner. |
Small Block Converter was behind a 305 Chevy small block. It is still available.
