Old 08-08-2014, 11:28 PM   #331
brent flynn
brent flynn's Avatar
Default Re: '67 Camaro E/SA redo
full floaters in my engine... im sure that was slowin you down a tad...
Old 08-09-2014, 04:31 AM   #332
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Yeah, a set of Manley rods will be attached to those CP pistons when I locate a set.
Rich Taylor
I/SA - 321
Old 08-10-2014, 06:55 PM   #333
HandOverFist
May have located a set of CP pistons from a forum member. Another slightly tech question - There are about 8 different Manley rods (large journal) listed in the S/SS blueprint sheet...anyone have the spec's on these rods or know which one I should be considering for this engine? (14101, 14350, 14201 ?) I'm thinking Manley 14101 would be the best bang for the buck here.
Rich Taylor
I/SA - 321
Old 08-11-2014, 07:07 AM   #334
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Those 14101 sportsman rods will work fine for you.
I used them in my late model LT-1 Stocker engine.
Same LJ crank pins
Rich Biebel
S/C 1479
Stock 147R
Old 08-11-2014, 07:16 AM   #335
Alan Nyhus
Liked 799 Times in 236 Posts
Rich, the Manley #14101 (14101-8 for a set) is the one you'll want. The Manley catalog claries things better than the NHRA accepted list: http://www.manleyperformance.com/master_catalog.shtml
I'm in the same boat as you....but have resisted taking the motor apart until the off season. -Al
"That'll never work....."
Old 08-11-2014, 07:22 AM   #336
HandOverFist
Thanks guys - That's the rod I will go with then. I may have the car back together in time to make a couple of end of year races. The plus side is the car will finally have some much needed fresh paint.
Rich Taylor
I/SA - 321
Old 08-16-2014, 09:53 PM   #337
HandOverFist
Back and forth between motor work and paint/body work...this weekend it is paint and body.
Took a razor blade to the doors to avoid having to deal with all the decal glue residue...didnt take too long as the paint was not adhered to the door panels very well to begin with.
I managed to get the front clip pieces along with the deck lid in shape today and I went ahead and painted the backside of all the parts. I have decided I will re-assemble the car and paint it as a whole...will make it much easier to color match all the panels and I won't have to worry with gouging/scratching finished surfaces.
Tomorrow I will detach the inner fender liners and freshen those up with paint. I'll then go ahead and assemble those to the fenders so I can make a straight shot re-attaching the assemblies.
This won't be a show car finish, but I will take the time to block outside surfaces. I went with the Sierra Fawn color in single stage so I can wet color sand and buff when finished. I know the base/clear would have been lighter, but I just have never been able to master laying down clear. On the plus side if it gets any gouges, dings or scratches I can easily repair them myself with this system. Another full day planned for Sunday...
Rich Taylor
I/SA - 321
Old 08-17-2014, 09:01 AM   #338
Alan Nyhus
Looking forward to the 'new look', Rich...and the new power! -Al
Old 08-17-2014, 08:50 PM   #339
HandOverFist
Lots of rain today and didnt do any spraying. My partner got ambitious and figured out how to remove the window trim and door felts so that part is out of the way. Seats are out and will be re-covered soon. My next project will be on the inside of the car taking apart the dash once more...going to need matching paint in the interior, right? That will be a weekender for sure with all the masking and detail work...hopefully I will get the door jambs/threshholds done at the same time. Oh yeah...removed the fuel cell so we could paint the trunk which has up to this point only been in primer.
Consensus - Black tail or not? If I remember correctly these were a matte black finish???
Rich Taylor
I/SA - 321
Old 08-18-2014, 10:39 AM   #340
Dion Hildebrandt
Dion Hildebrandt's Avatar
Black tail is my vote.......the sure come apart easy hey? JK
It sure is a sobering reality when "down on power" is the problem ,good luck with the freshen up!
Dion Hildebrandt 6009 STK H/SA
Dion Hildebrandt is offline   Reply With Quote
