Old 07-28-2014, 03:00 PM   #1
njk53
Default Air Lift - Air Bag
My brother and I just installed an Air Lift air bag on the right side of our Chevelle Wagon Stocker. How much initial air pressure should we run? Also, what do you guys think the maximum air pressure range would be? I am just trying to get a low/high range so we don't go overboard.
Nelson Kowal
Stock 345
Old 07-28-2014, 03:24 PM   #2
Brian Fink
Liked 28 Times in 9 Posts
Default Re: Air Lift - Air Bag
I've been there , done that ; save yourself a lot of aggravation and disappointment and forget the airbag idea . The best plan of attack is stock rear springs , a good set of control arms a rear bar like HRpartsNstuff sells . You won't be sorry .
Brian Fink is offline   Reply With Quote
Old 07-28-2014, 03:56 PM   #3
1720
1720's Avatar
Liked 2 Times in 1 Post
We tried them on the Malibu, before the $$$ for an ARB materialized. It does help with the body roll issue. We started at 8# and didn't go over 15#...your experience may vary, but I recall we were advised not to go lower than 5#.
RT - SS/X circa 1972.
Talbot Racing Family
1720 is offline   Reply With Quote
Old 07-28-2014, 07:45 PM   #4
Mike Merk
Mike Merk's Avatar
Liked 117 Times in 31 Posts
X2...Couldn't agree more. I purchased and bolted on an HR Parts N Stuff bar, with zero additional adjustments it did exactly what I apparently wasted A LOT of time trying to do with just shocks and air bags.
But to answer your question, I wouldn't go lower than 5#, and no higher than 15#. A lot of the range for me depended on tire clearance.
The ARB instantly took the body roll/twist right out of the launch. Before and after shots below.
Name:	Malibu 4-27-2014-twist.jpg
ID:	24867   Click image for larger version
Name:	May 24, 2014 new bar.jpg
Mike Merk
Mike Merk is offline   Reply With Quote
