i am starting the build of a 67 camaro stocker 396 325 hp was curious of a few things like rear wheel backspace can i run a rear spoiler with a cowl hood can i move the rear shocks on the back of the car? It has been slightly mini tubbed do i have to put that back to original
#2 | |
Liked 99 Times in 49 Posts
Liked 800 Times in 237 Posts
-Cowl hood: That's only for some '69's. Your combo used the raised SS hood.
-Rear shocks: Must be in original location. -Mini tubs: Must be original inner fender wells. As far as spoilers...not all '67-'69's can use the same combinations of f/r spoilers. I'm sure someone will clear up what can be run on your '67, though. -Al
"That'll never work....." |
Liked 53 Times in 16 Posts
I run a 396/325 motor. Look for the "290" heads, they came on 427/390 motors. Highest intake volume oval port heads made-
Good Luck! Will Lamprecht 65 Impala I/SA 396/325 in progress. |
Liked 33 Times in 16 Posts
15x10 w/5.00 backspace here. Pretty close, about the most you can get under these cars.
Rich Taylor I/SA - 321 Last edited by HandOverFist; 07-27-2014 at 07:54 AM. |
Liked 240 Times in 112 Posts
WOW !!! Look @ all the shiny.
Dave Noll, EF/S ,?/SA 6526 |
Look'n Good!!
Larry Fulton |
