Old 05-08-2014, 04:21 PM   #1
Doug McCue
Liked 13 Times in 2 Posts
Default NHRA Levied Actions Against Don Davidson
$1000.00 what exactly happened here?
Doug McCue is offline   Reply With Quote
Old 05-08-2014, 05:00 PM   #2
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Default Re: NHRA Levied Actions Against Don Davidson
I just talked to Don on the phone. No fines have been levied against him. So wherever you got that info its incorrect.
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 05-08-2014, 05:06 PM   #3
voltdr
Liked 100 Times in 51 Posts
NHRAracer.com
http://www.nhraracer.com/content/gen...988&zoneid=175
voltdr is offline   Reply With Quote
Old 05-08-2014, 05:29 PM   #4
Ed Carpenter
That was nice of Nhra to post that before calling Don. I'm not surprised though.
Ed Carpenter
Old 05-08-2014, 06:31 PM   #5
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Exclamation Re: NHRA Levied Actions Against Don Davidson
"The NHRA imposed a one thousand ($1,000) fine against Don Davidson for violating NHRA Rules, particularly Section 10A, page 2 of the 2014 NHRA Rulebook on Camshaft/Lifters and Carburetor. Tech inspectors discovered during the tear down process the intake valve lift and carburetor venturi exceeded NHRA specifications."
Old 05-08-2014, 08:50 PM   #6
NORVELL BOWERS
Send a message via Yahoo to NORVELL BOWERS
Anyone that knows Don,knows he would not knowingly do anything against the rules. I helped him with tear down and fully expected the car to pass. The carb was on the car when he bought it and had never measured the venturi's(how many of us have bought a carb and not measured it?) The lift on the intake was .007 ovr limit on the intake and .013 under on the exhaust. Don's main problem wound up being that he trusted the parts and work of others to be up to par. I think NHRA has way over done it in this case to a guy that just loves to race and supports the NHRA in every way. His car started running good because of good old fashion hard work from the front bumper to the rear,not a carb swap! A bunch of you guys know Don and know he is the kind of guy you want for a friend,honest and hard working.
NORVELL BOWERS is offline   Reply With Quote
Old 05-08-2014, 09:07 PM   #7
james schaechter
I guess the question about this is the process as administered by NHRA. What then determined a need for a fine and if a fine is to be administered, what is the process to establish the amount?
If NHRA wants this to be a deterrent, why not spell it out? Unless the car had a dominator on it, it would seem that the punishment did not fit the crime here. The lift sure wasn't extreme.
Is this in the rulebook or amendments to the rulebook in a very specific way or is it written by a Chicago Politician?
James Schaechter 3163 STK
Old 05-08-2014, 09:42 PM   #8
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Exactly. If this is going to be the way NHRA is going to be, they should let everybody know prior to the administration. Executive order, I guess. If you are needing money, nothing is off the table.
Old 05-08-2014, 09:44 PM   #9
SStockDart
SStockDart's Avatar
Liked 601 Times in 213 Posts
Based on what I have read.....the crime does not warrant the fine....note: I have been DQ'd for a half CC in the combustion chamber....later recinded. In this case....7 thou on the cam lift does not seem like much, but 1 thou is too much, but 1 thou would not get a fine...IMO....so the real question is....How big was the problem with the Carb? I'm just saying...
Old 05-08-2014, 10:11 PM   #10
NORVELL BOWERS
The Venturi area around the booster was .017 over size. I am not even sure how you could enlarge that area.
