Old 02-17-2014, 01:01 AM   #1
TOP GUN
Default Ford clevland size mains
Needing info on a 10 over front to back thurst bearing. too much crank end play. std bearing size. acl had what was needed but r out of business. king bearing only does 302 main size. not the 2.749 main size n this 9.5 windsor clevland main size block, will FE thurst bearings fit? thanks mark young.919-427-2747
nitro joes TOP GUN 3 years straight
mark young
TOP GUN is offline   Reply With Quote
Old 02-20-2014, 04:07 PM   #2
TOP GUN
Default Re: Ford clevland size mains
come on guys . is all of clevland snowed n?
mark young
Old 02-20-2014, 04:10 PM   #3
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
maybe call Jim Evanuik, 412-829-1988
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 02-21-2014, 09:44 AM   #4
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 313 Times in 106 Posts
FE & C thrust bearing specs are almost identical, FE housing bore (main od size in block) FE spec is .0005 smaller than C could put FE thrust bearing in C would have slightly less crush on bearing and would probaly have .0005-.001 more clearance.
Should be able to rebuild thrust without doing anything else to crank. If in rush maybe able to cheat it ,could possibly set cap towards front or back to offset thrust bearings to get by a race or two.
Mike Taylor 3601
Old 02-21-2014, 10:30 AM   #5
astikhossw
astikhossw's Avatar
Liked 20 Times in 9 Posts
Is it possible to have the crank and bearing coated to reduce the clearance.something that I had thought about, are would the coating just rub off.
7015 E/SA Sooner Storm
astikhossw is offline   Reply With Quote
Old 02-21-2014, 11:36 AM   #6
Hans Olsson
Hans Olsson's Avatar
Mark,
what is the clearance now?
Front to back?
Hans Olsson is offline   Reply With Quote
Old 02-23-2014, 12:45 PM   #7
TOP GUN
16 and nothing was galled. just shiny crank. mite just ride it till it causes a problem then weld it up if no oversize end play bearings r made for it.
mark young
