#11 | |
Liked 2,336 Times in 549 Posts
For the regular classes, I think that Chevrolet has done a very good job of looking after the older N/A combinations. |
#12 |
Mr Adams is this going to be a plan for the BODY IN WHITE???
#13 |
Liked 682 Times in 203 Posts
the 450 is a .100 stroked 427, same bore od 4.125, with mechanical roller lifters and they must have changed the head because there is a different part number. Fun to own one. Dyno
#14 |
Liked 24 Times in 13 Posts
Different piston config, more cam, more intake runner volume, bigger valves, more rocker ratio, etc. About the only thing you can use from a 427 are the rods, the manifold and throttle body, and the block.
MK
Mike Keener A/S B/S C/SM |
#15 |
#16 |
Nope...same exact block with a 4.200 arm, and the manifold and throttle body are exactly the same as the 12 and 13 427's.
MK
#17 |
#18 |
Liked 325 Times in 50 Posts
Started the process today to get that .200
Jeff Teuton 4022 STK |
#19 |
Liked 1,018 Times in 217 Posts
Brett Candies 4192 Stock/SS God Bless America |
#20 |
On my Mopo. 2.30 intake 1.70 ex. big new intake 699 cam 16 to one compression
