Old 12-09-2013, 05:14 PM   #11
Dave Gantz
Liked 251 Times in 125 Posts
Default Re: Starting problem
As a side note, be sure to use plenty of solder when attaching lugs to cables. You don't wnat just enough to hold it together, you want enough to make all of the strands into one, effectively, making it harder for corrosion to intrude.
Old 12-09-2013, 05:47 PM   #12
buzzinhalfdozen
Liked 11 Times in 8 Posts
Dave, also good advice. I will put the cable end in a vice test fit my cable then using a small torch I'll "fill" the cable end with solder about 1/4 way up then i'll push my cable into the solder and allow it to cool. Works great and you CANNOT pull the cable out,put a crimp in it a little shrink tube and you're set.
Joe Buchanan SS/BX 3117
Old 12-09-2013, 09:22 PM   #13
SmBlkFord
Thanks for all the info , All my connections are good , Have a #1 from the battery to the Ford style relay which I was told are the best ? Then from there I go 2.5' with #2 to the starter , All grounds are on bare metal , Not sure what the voltage drops too when cranking , What should it drop too ? Car is charged bettween rounds and I run an alternator , The voltage is fine for the entire run , never has gone under 12.9 volts , Is it possible to have good voltage and low amperage ?
SmBlkFord is offline   Reply With Quote
Old 12-10-2013, 01:45 AM   #14
Mark Ugrich
Liked 71 Times in 38 Posts
9.6 would be the minimum allowed cranking voltage.Typically 10.8 or more is normal cranking voltage depending on starter amperage.It is possible for an alternator to have "normal " voltage and low amp output.Normal charging voltage would be approximately 13.8 to 14.2 volts.Have you tried disconnecting the alternator?
Old 12-10-2013, 10:02 AM   #15
buzzinhalfdozen
Ok, have you done any testing yet? You really need some information to work with here, voltage drop testing is 1 sure fire way of finding your problem assuming your battery is up to the task. Kind of long winded to explain how to do it so if you like you can go to yellow bullet.com in the electrical section there is a pretty good explanation of how to do it and the results you'd expect to see. Give it a try and see what the results lead to. Good luck, Joe
Old 12-10-2013, 11:29 AM   #16
Jeff Niceswanger
Liked 1,075 Times in 380 Posts
Like Joe said ,check voltage at the S terminal for drop.
Also dont rule out the starter relay itself.
I've had a hot start problem ,and the volt drop across the solenoid was 3 volts when it got hot ! .
I cut it open to see what the problem and was shocked by how cheap it was .
This was an Echlin, but it was made in China.
I now use a AMETEK /Prestolite metal case solenoid with silver contacts.
The p/n is 15-108 , it can sustain 200 amps continuous ,and 600 amps intermittent.
the photo shows what most Chinese relays look like inside , pretty poorly built for our applications.
Boy, that brings back memories. From 1974 to 1981 I worked for Essex Wire/United Technologies and the department we worked in made that exact switch.. 8800 of them per shift,2 shifts a day. 125 women and 4 guys. ( The guys were... 2 maintenance men and 2 material handers. I was one of the maintenance guys.)There were 2 lines. The FORD line, and the Aftermarket line. Whenever we would get a new piece of equipment, a riveter or such, we would put it in the Ford line and take the old one over and put it in the aftermarket. Ford inspectors were always in looking over the parts that we were making .We had press rooms and so forth that made all the copper washers etc. If Ford rejected it, we just used it in the aftermarket line. Unless it was totally junk of course then we were forced to trash can it. They set the finished product "test sets" at a more forgiving voltage in the aftermarket line so as to not have to piss with that line as much. Anybody that says OEM and aftermarket are the same? Maybe they are now, but back then you got what you paid for....
On a side note, all the expensive cars like Lincoln ects, headlight switches and relays got pure silver contacts, where the Sable ects would get a copper contact w/a silver "tip" on it...But the switch from the outside LOOKED identical...Only way you could tell the difference was the part #.
And its been Oh so many years, but I'm thinking that across the 2 main contacts while engaged @ 12 volts the voltage had to be .2 volts or less for that switch to be considered good...
The entire plant picked up and went to Mexico in the early 90's. At its high point there was 1500 people working there. Thanks for jogging my memory Tom, I had some good times in that place....
Jeff Niceswanger 3740 SS
Old 12-12-2013, 11:55 AM   #17
63corvette
Liked 362 Times in 105 Posts
Tom, can you tell me where you find the AMETEK./ Prestolite metal case solenoids?
I have tried a coupe of the major chain Auto Parts houses and they are not able to find it.
I started to send this in a PM but thought others might want to know the answer also if you answered it in the forums.
Thanks
Rick Cates
63corvette is offline   Reply With Quote
Old 12-16-2013, 06:49 PM   #18
Alex Denysenko
Alex Denysenko's Avatar
Liked 4 Times in 3 Posts
i agree ground or poor solenoid just had a similar issue on our Ford class A motorhome
these are the only starter solenoids we use on our cars and trucks or sell any more even the Motorcrafts are now made in China.
http://www.allstarperformance.com/product.htm?prod=12
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK
Moneymaker Racing LaPorte Indiana 219-861-1214
www.moneymakerracing.net
Alex Denysenko is offline   Reply With Quote
