Old 10-21-2013, 10:50 AM   #1
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Best Place to Buy GM EATON 800 8.5" Posi
Time to find an 800# Eaton Posi.
1995 Impala SS 8.5 Inch Rear.
My 400lb will not hold the launch RPM.
Over 2500 rpm the Tires become unhinged. At or below launches fine.
Use to hit it at 3000 when the rear Brakes Held the Torque.
That is another fix coming.
Driving to the tracks and street most likely weakened the Grip Capability.
Want to buy a Eaton 800# but need advice the on better Clutch Pack.
Will then rebuild the current one but need advice on which Clutch Pack to use or have it Rebuilt.
Dan
Dan Fahey is online now   Reply With Quote
Old 10-21-2013, 11:53 AM   #2
Tar Heel
Guest
Posts: n/a
Default Re: Best Place to Buy GM EATON 800 8.5" Posi
Dan
How about a spool now Dan since you're looking into a trailer?
Old 10-21-2013, 12:22 PM   #3
Dan Fahey
Dan Fahey's Avatar
Scott:
Love the idea but in Pure Stock not allowed a Spool..
Dan
Old 10-21-2013, 01:52 PM   #4
Tar Heel
Guest
Posts: n/a
Scott:
Dan
RATS! Now I have to take my rear-end apart this winter ...
Old 10-21-2013, 03:10 PM   #5
FED 387
Liked 336 Times in 183 Posts
Dan--- why don't u just buy the 800# preload kit available under Eaton part number 29591-OOS this is the 800 pond pre load kit springs & plates available from Summit for $89.97 ---by th way Summit shows a picture of it ----Has to be cheaper than buying a whole posi unit for about $450 ---Good luck FED 387
Old 10-21-2013, 05:17 PM   #6
Dan Fahey
Dan Fahey's Avatar
Originally Posted by FED 387 View Post
Dan--- why don't u just buy the 800# preload kit available under Eaton part number 29591-OOS this is the 800 pond pre load kit springs & plates available from Summit for $89.97 ---by the way Summit shows a picture of it ----Has to be cheaper than buying a whole posi unit for about $450 ---Good luck FED 387
Thanks FED..
Yeah, seriously thought about that..!
A new Posi would be twice the cost to rebuild but simpler quicker to install.
PN for the Springs is $90, Carbon Disks another $119.00.
It is still good for the street and drag racing.
Have the option keeping it for a street project, the 94 Caprice SSuperwagon being set up for towing or sell to a B-Body racer.
Should be a wash after selling it.
In past have rebuilt a 12bolt Moroso Posi with new Springs from Al's Differentials.
Built a clamp tool out of 2x4 and to force them inside the cavity with a hammer.
Eaton has three types of clutch service kits.
OE, 18 disc (standard), 24 disc (high performance), the modern day, high tech 14 disc carbon fiber design.
Last night studied all about their characteristics.
Still need advice on which of the last 2 to buy.
Dan
Old 10-21-2013, 09:52 PM   #7
Tim Kish
Liked 11 Times in 4 Posts
Call the Eaton tech line: 800-328-3250 Either Barney or Brent should be able to steer you in the right direction.
Tim Kish
3032 SS/GS
Tim Kish is offline   Reply With Quote
Old 10-21-2013, 10:57 PM   #8
Dan Fahey
Dan Fahey's Avatar
That is great information..thanks.
D
Old 10-22-2013, 11:45 AM   #9
Dan Fahey
Dan Fahey's Avatar
FYI..that Number is for some Florida Vacation spam..
Here is his correct information
Brent Bussell -Customer Support
Technical Specialist
Phone# (248)226-6762
Fax# (248)226-6740
Old 10-22-2013, 02:16 PM   #10
FED 387
toll free # is 800-328-3850 x 6762-otherwise the other # is his direct line phone #-FED 387
