#51 | |
Liked 373 Times in 131 Posts
I could do the same with my PS Mustang. It still has front and rear sway bars hooked up as well as the factory struts and shocks. I also have a set of 17 x 9 wheels w/275 radials if needed. Not sure how my Pure Stocker would work on a auto-x with those 4.56 gears tho. Overdrive trans is a push button switch away. ![]() I have tried autocross with my other '95 Mustang GT and man is it rough on tires and suspension parts. But it sure was fun.
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
#52 |
Liked 184 Times in 113 Posts
Tom Gould's CORVAIR could dust all of us..
AND he does not even need Power Steering... ![]() |
#53 | |
79 Pontiac Firebird, Trans Am body. Not a good selection of available engines. One Chevy, 350/175, very expensive engine to build. I believe (may be wrong) the 400 Pontiac or the 403 Olds was the standard available engine. When I started disassembling the car. After looking over the options, the IHRA crate motor looked like the best chance to get an engine up and running that could make it's index. Which would've given me a car that could run the combos here in the midwest. Yes, most of the pieces would be sufficient for a late 70's-early 80's NHRA SBC shortblock. Change heads, intake, cam and carb. Then I would need another body, lol! I guess I just don't have illusions about running NHRA events.
Robert Swartz - Swartz & Lane 66 Chevy II Pro 95 Achieva EF/SA, 78 Mustang II U/SA (work in progress) #354 stock |
#54 |
Liked 360 Times in 121 Posts
OK!! Picked car up on sat am, mounted wheels and tires and went racin sat sun. Not bad although a lil slower than I had hoped. It was AFRICA HOT THO!! Ran 14.30's and high 9.teens/20's in the eigth. Fairly consistent and easy to hit the tree in. Looks like D/PS it is although I will need to get just about 100lbs out of the car and speed it up considerably with an 8.50 index. First thing on the slate is a converter. The stock one is TIGHT! Can barely footbrake it to 1500 before it pushes through the brakes. Looking at a Yank 3800-4000 stall. Any pointers? And guys with experience how much did you pick up with a good converter. Most say 1/2 sec should be easy with a good one. Headers and gears next up.
#55 | |
Liked 5,149 Times in 1,966 Posts
#56 | |
Guest
Posts: n/a
#57 |
PM sent. Thanks!
Thanks Scott. Did it pick up a sec in the 1/4? If so how much 1/8th? Either way IMPRESSIVE. Got a line on some headers, gears next. I'm hoping between these three main things (converter, gear, and headers) PLUS getting about 100 lbs out of the car I can run the index or better. Need 7 tenths in the 1/8th (8.50 index). |
#58 | |
Guest
Posts: n/a
#59 |
Luckily I have a longtime bud down here about 30 min away who is a guru and has a chassis dyno. One thing I am going to look at is a shift kit or manual valve body. This weekends shakedown showed me a few things. The old owner said he shifts it himself @ 5k. I tried shifting it as well as leaving it in drive. When I shifted it a 5k it didn't really shift till about 5500-5600. When I left it in D it shifted itself right at 5600. I felt like it was nosing over just a tad both ways. The et was faster by .04-.05 shifting it. I really feel like short shifting it a lil will help a bunch.
#60 |
Guest
Posts: n/a
That's good that you know a reputable tuner. That can make all the difference in getting a car to run the index as well as having a reliable, consistent Stocker.
Speaking of consistent ... I've never shifted any computer-controlled car that I've raced. Turn the traction control off, put it in drive, and go. My thinking is that I'll never be quicker than any computer and definitely I won't be more consistent. Even if I picked up a hundreth or two I want the consistency. When we work hard to regulate the water temperature and ice the intake if traction stays our car is deadly consistent on the ETs by not shifting it. |
