Go Back   CLASS RACER FORUM > Class Racer Tech > Garage Tech
Old 09-01-2013, 08:27 AM   #1
Bobby Fazio
Bobby Fazio's Avatar
Default Lift for 8' ceiling
Does anyone have a little lift recommendation for my house garage? Only has 8 foot ceiling but looking to just get the cars about 3 feet off the ground to make working on them a little easier than jackstands and lying on my back. Is scissor lift best for this? Thanks.
'65 Mustang SS/L & L/SA
Old 09-01-2013, 07:40 PM   #2
tj310
Default Re: Lift for 8' ceiling
Scissor lift is in the way for any driveline work . I put a 2 post lift in 10' posts , by removing a couple of rafters for the top of the car. 1 post still hit so I installed a skylight. --- Trevor
Old 09-02-2013, 11:40 AM   #3
Harry 6674
Northern Tool sells a two post with a 48" lift. It's portable.
Harry 6674 is offline   Reply With Quote
Old 11-18-2013, 12:36 AM   #4
Tom Goldman
Tom Goldman's Avatar
Liked 859 Times in 234 Posts
Bobby, I dont know if you found a lift yet , but this Atlas lift from Greg Smith Equipment in Delaware has been great in my small shop at home.
I recessed it 4" into the floor for tube chassis cars ,but it will easily clear most S/SS cars installed on the floor . ....I've added a plate in the center since this photo so I can roll a trans jack or a mechanics stool around .
Cost about $2200 and worth every penny has worked flawlessly.
Tom
Name:	camaro &nova 004 (Copy).JPG
Old 11-18-2013, 05:44 PM   #5
chevy620
Banned
Can you get under it far enough to swap trans? Can't tell if the cylinders are in the way or not.
Thanks for any info, appreciate it.
Jok
chevy620 is offline   Reply With Quote
Old 11-19-2013, 12:20 AM   #6
Tom Goldman
Jok, The lift has two ramps are 19'wide x56' long with 26" between the ramps. ...The cylinders are under the ramps.
I fabricated lifting brackets with saddles to fit round and square tube chassis. Conventional perimeter frame or unit body cars can be lifted with the supplied hard rubber blocks directly on the ramp ,
Plenty of room to do a trans or just about anything else... Its been really great for fabrication.
I have a lot of pictures of the install ,but they are on my other computer.
If you would like ,I'll post some more of them later.
Old 11-21-2013, 07:15 PM   #7
greg johnson
Please post more of your installation. Thank You!!!
Greg Johnson 3123 STK
greg johnson is offline   Reply With Quote
Old 11-21-2013, 10:20 PM   #8
Tom Goldman
Here's some photos from the install
You can see in the last shot I laid 2"schedule 40 pvc under the floor and extended the hydraulic and pneumatic lines to mount the control unit on the wall in the corner.
A 12x12 conduit box next to the lift houses the connections for the hydraulics ,and a 110v feed for receptacles and lights.
If the concrete form looks odd, its because we discovered after the initial cut the sides were not going to be acceptable due to the floor consisting of 4" of waylite concrete,topped with 2" of Portland cement. ....Who knows why, it was done 50 years ago.
Name:	100_0019 (Copy).JPG
ID:	22227   Click image for larger version
Name:	100_0020 (Copy).JPG
ID:	22228   Click image for larger version
Name:	100_0022 (Copy).JPG
Name:	100_0024 (Copy).JPG
ID:	22230   Click image for larger version
Name:	100_0031 (Copy).JPG
ID:	22231   Click image for larger version
Name:	100_0032 (Copy).JPG
Name:	100_0033 (Copy).JPG
Old 11-24-2013, 08:34 PM   #9
greg johnson
NICE install, Tom............ Thanks for the pics!
Do you ever wish @ times you had left it "portable"?
Or wish you had provided a drain (of some sort) to let any water "out" that inevitably gets in the pit?
greg
Old 11-25-2013, 09:12 AM   #10
Tom Goldman
Thanks Greg.
Im going to do a second lift in the spring , but portable is a relative term for these lifts.
Yes, they have rollers and a dolly for moving and manuvering, but it is very heavy, not like the flimsy single cylinder arm type lifts you see in the pictures of them inside and outside.
Also, I probably would have had a harder time with very low tube chassis cars , as the ramps are 4' high. ....they do give you 4, 20" long angled ramps that attach front and back for a conventional on the floor use .
most cars will easily go over them,but some of the ground scrapers I work on needed the extra clearance.
Floor drains are a no no in my Township ,so I had no choice there, but it has'nt been an issue.
Just a regular vacuuming under it.
The pics dont show the center cover I made to close the floor between the ramps......That made it easier to keep clean ,and roll around on a creeper or stool.
