#11 | |
That is super easy to do with your domestic V8 car as that flange sticks through the adapter plate and mounting flange of the block. Mine is recessed inside of the mounting flange of the block and inside of the adapter plate. So that hole HAS to be bigger to accommodate the radius on the back of the flywheel so we can safely bolt our flywheel to the engine. Their solution is to run a hub adapter or some weird sort of spacer to get the crank mounting flange past the adapter plate to where we can bolt the flywheel to. Anyone with any experience with a buzzy inline 4 cylinder car knows that it's hard keeping any bolt in that engine, let alone a flywheel bolt. So in their "fix" I would have to run really long flywheel bolts and some sort of spacer. That too me seems way more dangerous than a larger hole in the adapter plate that goes no where except into the back of the block. And honestly it's extremely close to the radius of the flywheel so in the end the hole in the adapter plate, once the flywheel is bolted up is actually non existent. Last edited by boostedf22c; 08-31-2013 at 09:53 AM. |
#12 | |
Wow. I understand the rule as written, and you're right. It was never written with modern import engines in mind, and is probably decades old. I think a few calls to Glendora, and talking to Pat or some of the others might make you some headway. I think a better solution than a spacer would be to have the crank made a little longer to move it back, if NHRA won't bend on the rule. I hate you had that happen, your car is really cool.
Chad Rhodes 2113 I/SA |
#13 |
Liked 32 Times in 19 Posts
Guys got to realize that keeping the tech men up on 1million combinations in Stk and SS cannot be done and should not be expected. Keeping the combinations "simple and limited " can be an answer but no one will listen to that one. Everyone fears lack of innovation, lack of their own car, lack of their own brand.........lack of racing the combo they currently own..and understand.
Everyone rather sacrifice the whole sport while continuing to play the same games year after year. Run what they allow today and "Bi####" about cost, tech, rules etc. Complain about no sponsors, no crowd, no heads up racing.... A clean start class with spec , sealed motors could recover the crowd, cut the cost, increase the interest of sponsors and NHRA but I doubt support could be found anywhere It cannot be done by one man, one group or brand. (MOPAR shoot out is the exception or example of supporting a concept. Not everyone can afford a 200,000 program. Allow any body you have at a fixed wt and cubic inchs spec or sealed motor and at least people could test the water with their current car and a cheaper motor combo to see if it works. |
#14 |
Hey Carey, Why not stud the crank hub? Use long studs, slide the spacer then the wheel on. Im sure ARP would make them to any spec you need. It would be just like the clutch set up in top fuel cars then....Studs give more clamping force and are "safer" right and you spend more money right? Good luck in your fight!
Kenny Newsome 7709 ?/SA |
#15 |
Liked 535 Times in 86 Posts
You guys think it's bad when you hear this stuff in the stands? How about when it comes out of the track announcer's mouth across the loud speakers? I heard, during a couple of heads up runs at Atco, a double breakout!
But the best had to be hearing over and over that ONLY round winners return to the lanes! |
#16 | |
No prep is king |
#17 | |
Liked 359 Times in 135 Posts
#18 |
I've been here since Thurs and have heard a few funny things here and there. But more than hearing is the seeing, there's been some outstanding people watching. The nitro cars bring out some amazing mullets, I have pictures if anyone is interested : )
#19 |
Liked 2 Times in 2 Posts
Oh yes, please post them!
Steve Jackson |
#20 |
Well if you look close in any of espn 's broadcast you will see that on both sides in the last set of the stands are blacked out
