I have a 78 Fairmont 2 door 200 c4 all original any potential in this combo?
#2 | |
I did have a 79-80, can't remember which. Bought it as a beater back in 87. Drove it until about 1995. It was pretty rough when I bought it and rougher when I sold it, lol. Some kid bought it and rolled up and down the roads here for awhile. Then it disappeared. That old car was tough as nails. It had a 2300 with a four speed. Looked it up, I'm dumb. It is a 200ci 6 cylinder. Factory hp is 85. NHRA rerate is 140hp. The car is a natural R. I'd move it up to T, the index is 14.40. Just doing some quick figuring, if at 19lbs for T. Minimum weight for the car with you in it would be 2830lbs. It would take approximately 190hp to get to the T index. I'm sure Billy, Yac or Dwight Southerland could tell us whether this combo has any validity. I'm willing to bet the Ford 200 could be capable of making hp, just not sure about this version of the 200. As a racing combo, just have to poke around the guide and see where it lands.
Robert Swartz - Swartz & Lane 66 Chevy II Pro 95 Achieva EF/SA, 78 Mustang II U/SA (work in progress) #354 stock Last edited by Robert Swartz; 08-30-2013 at 06:54 PM. |
Liked 9 Times in 9 Posts
I tried it in a wagon. It's got potential, only if you can get the NHRA to refactor it to where it belongs, like V. Not sure where they got 140hp; I was told it was a typo and should be 114? The combo works in older Mavericks and Comets. Dave Turner on here used to run one. The integral head and intake design is a bottleneck. the plus side is Fox-body parts are cheap. My wagon came manual brakes and steering. I was thinking if the refactored 302s stay the way they are, then a guy would have something!
I don't think it would make 140 with a turbo???? I'm just thinking outloud may just put adapter on it with 2v and bracket race it! Anybody have a camshaft for this what specs is the cam anyway if anybody wants to tell?
Keep duration at .050 around 240. Lunati does have a grind for this motor. Check out www.classicinlines.com, all he does is inline Fords, especially the 200. They can make 230-250hp with some work, in stocker trim I'd guess 150 max? The head/intake design is poor.
I think the best route would be a 302, very cheap to build and find headers, etc. for, plus a 4cyl. K member is the same as a V8. If it stays at 139, I'd say U/SA terror. If it goes back to the original 162, I'd think it would at least hit the Q or R index?
I am still thinking about getting my old wagon back and going V8... |
#7 | |
Here again, a good budget C4, a small converter. Some gear and a set of tires that would work. You could start out with a set of drag radials like I've done with my Achieva. At least starting out, you shouldn't kill the tranny and rear end. Pretty sure you could find some kind of headers. I may be way off base here, fun excersize. Then again, the 302 might be the better way to go.
Robert Swartz - Swartz & Lane 66 Chevy II Pro 95 Achieva EF/SA, 78 Mustang II U/SA (work in progress) #354 stock |
Classic Inlines makes a header; Hooker does for the Maverick, which could be modified to fit. Going junkyard crawling, look under Aerostars and Rangers, they often have limited slip rears with 3.73 gears, and 4cyl Rangers sometimes have 4.10s.
#9 | |
Liked 373 Times in 131 Posts
Looks promising. I had a '79 Fairmont 2 door with the original 200 six but it had the V-8 /2.3 k-member, so I think the oddball 200 six x-members came out in 1980-1981 or so. Not sure tho. Cool cars and they be gotten down light because they came from the factory with thin glass and sheet metal as well as aluminum bumpers.
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
I don't know much about the rules but if I changed it to a 302 would another year block pass if the heads were right or can it be done like that? Yea the Fairmonts are kinda neat I have 2 one is completley original and it also has a vinyl top! They have more over hang than a Mustang which should help also? Wish I could use a 289 I have a complete 66 engine?
Thanks! |
