Liked 4 Times in 2 Posts
In going from C12 or C14 to C25, how much larger jet is usally required in a holley 750 or similar sized carb. It seems about 2 sizes may be in the range, any throughs or comments appreciated. Thanks Bob
Liked 693 Times in 205 Posts
I found 2 jet sizes worked on the dyno going from 14 to 25.
#3 | |
For instance, switching from a fuel SG of .720 to a fuel of .725 SG wouldn't require a change in jetting. switching from a fuel SG of .720 to a fuel of .730 would require a change of 1 size in jetting. And switching to oxygenated fuels will usually require up to four jet sizes higher to start. Start out easy and let the plugs ( read all of them, not just a couple ) be your guide for further changes. |
I tested C25 against C12.
Found it gave me 1 mph but lost .05 overall. Lost .10 in the sixty, .15 in the eight, but picked up .10 in the second half of the track. This was just make 3 runs, change fuel, make 3 runs, back to original fuel make 3 runs. I believe the C25 would be beneficial if I can do some tuning. But 9 runs in a day was enough. Later I might put the C25 back in and do some tuning. If I can get it to leave like the C12 it will be overall quicker. But so damn expensive.
Art Leong 2095 SS |
Liked 12 Times in 6 Posts
Bob give me a call or shoot me an e-mail and I will talk to you about C25. Are you trying to switch to C25 for your Fairlane?
Liked 22 Times in 22 Posts
Did anyone's timing change with C-25?
don,t have one |
Run one - two degrees less timing.
Thanks. I've seen as much as 4, and as little as 1 degree difference. Just wondering if I was seeing right.
don,t have one |
