Old 08-27-2013, 01:17 PM   #1
richie 2
Liked 205 Times in 93 Posts
Default Gm f body engine cradle
'96 Camaro w/factory v6 engine cradle/crossmember...are they the same as the v8 units? theres a large v6 stamping on the one I want to prep for a 350ci motor. tks.
Old 08-27-2013, 01:41 PM   #2
CJ Perry
CJ Perry's Avatar
Default Re: Gm f body engine cradle
if you are asking if a gen1 SBC will bolt into the factory motor mount the answer is no. You will need to install a motor plate or buy an aftermarket k-member that uses the SBC mounts. FYI an aftermarket front suspension is illegal in class racing.
CJ Perry
9931
PCA-1
CJ Perry is offline   Reply With Quote
Old 08-27-2013, 01:53 PM   #3
countrypuppy4865
countrypuppy4865's Avatar
Liked 229 Times in 71 Posts
There are some places that manufacture solid mounts that go from Lt1 cradle to LS1 or LS1 to LS1 or LT1 or LS1 to SBC. To my knowledge, there are no places that make motor mounts that go from V6 cradle to anything else. If you are NOT running stock or super stock, you may want to consider buying an aftermarket tubular cradle. BMR has some nice pieces, that save weight and gives you more room to work.
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
Old 08-27-2013, 01:54 PM   #4
richie 2
tks cj...my ;96 came w/factory V6 engine. im prepping its engine cradle and want to get V8 motor mounts from say FJ smith to install a 1995 (factory roller) 350ci unit...
Old 08-27-2013, 02:04 PM   #5
Rob Petrie E395
Liked 216 Times in 77 Posts
I think FJ Smith can make his mounts about any way you want them. ( IE V6 cradle to LT1, V6 cradle to Small Block, V8 cradle to small block ect.) Might give him a call if its for a race car. Also if you are in the midwest there are plenty of places around here that you can get a V8 cradle if you would rather go that way I might be able to help you track one down.
Old 08-27-2013, 02:16 PM   #6
richie 2
thankyou for your prompt replys... FJ has them in stock....which ever way you want them.
Old 08-27-2013, 05:38 PM   #7
GUMP
Liked 2,361 Times in 558 Posts
You can't go wrong with FJ's mounts. The fit is great in my Firebird.
GUMP is online now   Reply With Quote
Old 08-27-2013, 05:43 PM   #8
CJ Perry
CJ Perry's Avatar
How do the fj mounts work? On my stock k-member my brackets are cut off. Can I weld these on to get rid of the motor plate??
CJ Perry
9931
PCA-1
Old 08-27-2013, 06:47 PM   #9
SPS
Liked 3 Times in 2 Posts
E-mail me a pic and I'll see what I can do.
info@smithperformance.com
FJ
SPS is offline   Reply With Quote
Old 08-27-2013, 07:45 PM   #10
Rob Petrie E395
They bolt on using the holes where the stock mounts bolt to the K Member. They are a very nice product.
