Old 08-07-2013, 12:45 PM   #1
Jeff Teuton
Liked 325 Times in 50 Posts
Default DP rear axle assembly
I think you will see something like this on the tech section, but a reminder to DP racers. The 9" rear is legal in a V10 car or a new 426 Car only, otherwise the 8 3/4 or Dana and the 9 1/4 or 8 1/4 if you are really brave are the accepted rear axles for these cars. Don't want anyone to show up and have a problem. This is for Stock Eliminator. From your roving reporter.
Jeff Teuton 4022 STK
Old 08-07-2013, 02:45 PM   #2
rickseeman
rickseeman's Avatar
Liked 2 Times in 2 Posts
Default Re: DP rear axle assembly
If anybody needs a 9" out of a 2011 Drag Pak, I have one that I don't need. I took it out when I tubbed the car. Includes axles.
rickseeman is offline   Reply With Quote
Old 08-07-2013, 03:19 PM   #3
Eric Merryfield
Eric Merryfield's Avatar
Liked 503 Times in 131 Posts
Cool Re: DP rear axle assembly
For the super brave I have a NOS in the box sure-grip for the 8 1/4...I wouldn't do it but you could....the 9 1/4 will not work due to lack of Spool and gear choices.....but you could run it with a sure grip, I run a nice detroit locker in the Lil Red this way.
8.75 and dana 60 are your logical choices, more gear choices for the dana 60 and of course it will live behind any of the DP motors, whether or not you gain any ET with a 8.75 is a consideration, as is your tranny if the ring and pinion goes.
Eric Merryfield 1883 STK
Old 08-07-2013, 06:20 PM   #4
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: DP rear axle assembly
Wasn't there a SS/AA Cuda racer here in the southeast that ran a 9 1/4 rear? He later tried Pro Stock - Maybe a Duster, then Volare. X&*#@* I can't think of his name. (Not Bagwell.)
A Dana 60 is actually a pretty efficient rear due to the ring & pinion orientation. 12 bolt is the best and 9" the worst. There was a magazine article about it years ago. I've heard of some racers switch between the Dana 60 and 8 3/4", adjusting the overall weight, and didn't see any ET difference worth mentioning.
Old 08-07-2013, 08:12 PM   #5
Stewart Way
Liked 70 Times in 22 Posts
Myron
Are you thinking of Jim Kinnett? I know he ran a 12 bolt gm but don't remember the 9 1/4.
Stewart Way 2424 SS
Old 08-07-2013, 09:17 PM   #6
Myron Piatek
Thumbs up Re: DP rear axle assembly
Originally Posted by Stewart Way View Post
Myron
Yes, Jim Kinnett. I suppose someone could have confused the 2 rears. I didn't see it myself. Thank you for clarifying that.
Old 08-07-2013, 10:15 PM   #7
340Cuda
Liked 805 Times in 341 Posts
To reinforce what Myron was saying, we went from a 8 3/4 to a Dana 60 many years ago and in spite of the additional weight no change in ETs. The only real difference is that it quit spitting the gear out after trips thru a dip that was in the left lane in Tulsa at the time.
Bill
Old 08-08-2013, 12:10 PM   #8
DonatoEng
Liked 8 Times in 5 Posts
Jeff, That would make a 9" legal in an 09 or 10 DP with the 426, but illegal with all other engines.
And the reason ?
John Donato Stk / SS 3435
DonatoEng is offline   Reply With Quote
Old 08-08-2013, 02:20 PM   #9
Stewart Way
There was no 426 or 9" in the 09 and 10. Not till 11.
Stewart Way 2424 SS
Old 08-08-2013, 09:32 PM   #10
Jeff Teuton
Any DP with a 426 Aluminum motor is a 2011.
