Liked 325 Times in 50 Posts
I think you will see something like this on the tech section, but a reminder to DP racers. The 9" rear is legal in a V10 car or a new 426 Car only, otherwise the 8 3/4 or Dana and the 9 1/4 or 8 1/4 if you are really brave are the accepted rear axles for these cars. Don't want anyone to show up and have a problem. This is for Stock Eliminator. From your roving reporter.
Jeff Teuton 4022 STK |
Liked 2 Times in 2 Posts
If anybody needs a 9" out of a 2011 Drag Pak, I have one that I don't need. I took it out when I tubbed the car. Includes axles.
#3 | |
Liked 503 Times in 131 Posts
8.75 and dana 60 are your logical choices, more gear choices for the dana 60 and of course it will live behind any of the DP motors, whether or not you gain any ET with a 8.75 is a consideration, as is your tranny if the ring and pinion goes.
Eric Merryfield 1883 STK |
#4 | |
Liked 138 Times in 51 Posts
A Dana 60 is actually a pretty efficient rear due to the ring & pinion orientation. 12 bolt is the best and 9" the worst. There was a magazine article about it years ago. I've heard of some racers switch between the Dana 60 and 8 3/4", adjusting the overall weight, and didn't see any ET difference worth mentioning. |
Liked 70 Times in 22 Posts
Myron
Are you thinking of Jim Kinnett? I know he ran a 12 bolt gm but don't remember the 9 1/4.
Stewart Way 2424 SS |
Liked 805 Times in 341 Posts
To reinforce what Myron was saying, we went from a 8 3/4 to a Dana 60 many years ago and in spite of the additional weight no change in ETs. The only real difference is that it quit spitting the gear out after trips thru a dip that was in the left lane in Tulsa at the time.
Bill |
Liked 8 Times in 5 Posts
Jeff, That would make a 9" legal in an 09 or 10 DP with the 426, but illegal with all other engines.
And the reason ?
John Donato Stk / SS 3435 |
There was no 426 or 9" in the 09 and 10. Not till 11.
Any DP with a 426 Aluminum motor is a 2011.
