Old 06-12-2013, 11:43 AM   #31
C and W Racing
C and W Racing's Avatar
Liked 13 Times in 3 Posts
Default Re: Impossible to achieve high 1.20s sixties
Originally Posted by Stephen & Horace Johnson View Post
clutch, rpm, susp, tire.... Our 3300lbs sled cuts high 1.20s on a good track and low 1.30s on a greasy track...we took the car to one of the worst tracks in the country and cut a 1.27 by tuning,tuning, tuning...
I agree with Brad, first off stop the thing from rolling...
You forgot to tell them you did that with the back tires. Lol
Chuck
C and W Racing is offline   Reply With Quote
Old 06-12-2013, 04:32 PM   #32
Mike Pearson
Mike Pearson's Avatar
Liked 1,958 Times in 593 Posts
Chassis looks to stiff. Does not seem to plant the back tires. I would guess something is in a bind in your rear suspension. You have plenty of power. With the short times you have posted mid 1.20 60 Ft times should not be a problem. Check all of your angles on the ladder bars and pinion angle. Loosen the rear shocks and let the suspension work. Is that a mono leaf spring?
Mike Pearson 2485 SS
Old 06-12-2013, 04:45 PM   #33
Jeff Lee
Jeff Lee's Avatar
[quote=joespanova;385959]
Originally Posted by Jeff Lee View Post
And then we found out what was wrong with the chassis and it's been parked since.
QUOTE]
so bad it was never fixed?
New engine was supposed to be on the dyno two days ago but as usual, the shop has something ahead of me. Once that's done, fix the chassis. The driver side floor at front leaf spring mount was pushed up the rocker panel.
Adding Calvert single wheelie bar and fix this and that and go racing. But today it's 112* outside so motivation to work outside is super low!
Jeff Lee 7494 D/S '70 AMX
Old 06-12-2013, 05:31 PM   #34
joespanova
Liked 13 Times in 11 Posts
Yes........
and I can definately stand to loosen the rear shocks...........I had a suspicion they may be too tight.
Old 06-12-2013, 05:39 PM   #35
joespanova
I also want to add.........nothing is "in a bind" , both ladder bar front bolts are always loose , floaters are oiled ( basically WD-40 ) and springs have poly / graphite bushings ......everything moves freely.
In the pic below everything is as now with the exception being the Afco double adjustables it now has......
Old 06-12-2013, 05:42 PM   #36
joespanova
Old 12-04-2014, 11:14 AM   #37
KLORD
What gear box are you running in the nova?
KLORD is offline   Reply With Quote
Old 12-04-2014, 11:59 AM   #38
Ed Wright
Ed Wright's Avatar
Eastexas Racecars can fix that for you. Some of the best money I ever spent. My SS/JA car, when I have the extra weight out of it, goes 1.26/1.28 all the time. Immediate problem was curing red lights. Didn't realize it reacted so slow until first time I let go of the button when I got it back. People bring cars from both coasts to those guys. Every time I go there, I see another big name car from a long way off.
Ed Wright 4156 SS/JA
Old 12-04-2014, 02:28 PM   #39
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Originally Posted by ed wright View Post
eastexas racecars can fix that for you. Some of the best money i ever spent. My ss/ja car, when i have the extra weight out of it, goes 1.26/1.28 all the time. Immediate problem was curing red lights. Didn't realize it reacted so slow until first time i let go of the button when i got it back. People bring cars from both coasts to those guys. Every time i go there, i see another big name car from a long way off.
x2
