#11 |
I started running an Innovators West. I took it off because I thought I damaged it installing it. I sent it back and there was nothing wrong with it.
Now I'm running a solid metal pulley. This is an inline 4 cylinder. Quite a bit different than a V8.
Art Leong 2095 SS |
#12 | |
Here is a link with some good discussion on the subject: http://www.eng-tips.com/viewthread.cfm?qid=107602 |
#13 |
Artie, I would see if I could get Raymond Martin, (Baytown Texas?) to talk to me.
Ed Wright 4156 SS/JA |
#14 | |
The one substantial difference is they are turbocharged. And I have to extract as much power as I can because of my lack of pressureized air. I ran a crank with the counterweights removed. I'm starting to see that most if not all of my problems since I put this motor in the car. Might be traced back to the harmonics. My first problem was a broken stator support in the trans. Another problem that nobody that runs automatics and these motors had ever heard of. The first motor I built was a mild (get to know the combo) verision. It ran trouble free for 2 years. And when I wanted to go fast it was shifted at the same rpms. With over 200 runs (a lot with improper fuel mixtures) the bearings looked like the day I built the car. With the new motor the bearings allways looked weird (like there were oiling issues) in places that should not show issues. This was verified by this this time the rod bearings had only one easy run.
Art Leong 2095 SS |
