Old 04-17-2013, 07:01 PM   #31
Joe Toller
Liked 9 Times in 9 Posts
Default Re: Project Junkyard Dog
Not much to report, except I came a across an MSD 6-BTM and 2-step off craigslist for $160, and since this thing can shift itself, I sold my ratchet shifter for $100. It's still snowing, so I am at a mild standstill.
Old 04-18-2013, 04:10 PM   #32
That was your best investment so far...
Old 04-20-2013, 07:08 PM   #33
Joe Toller
Well I got a little done today before Mother Nature revolted, the engine compartment is ready for the pressure washer and some rattle can flat black. I threw in a couple newer pics, how about that patina? I kinda wanna keep it...
I also made a run to the wrecking yard, and scored a couple pieces I need, which lead to my cheap tips of the day:
Need a high output coil? Check out a TFI coil on a fuel injected 5.0 Ford. They're 40,000 volts and fairly compact. I got one for $5
Need a cheap GM mini starter? Try a 94-98 GM pickup 350, 96-98 S-10 or Blazer 4.3, or 97-98 Astro. Compact, gear-reduction, and in my case, $10!
I also threw in a pic of my 95 Cougar electric fan, fits a GM radiator perfectly.
ID:	18562   Click image for larger version
ID:	18563   Click image for larger version
ID:	18565   Click image for larger version
ID:	18566   Click image for larger version
Old 04-20-2013, 07:17 PM   #34
Billy Nees
Good Buzzard!
Billy Nees 1188 STK, SS
Old 04-30-2013, 10:01 AM   #35
Joe Toller
Well, the Dog is plumbed and wired, suspension is all done, and the short block is awaiting a cam (HUGE thanks to Bob Shaw). Heads are almost ready to pick up too. I went through the th350 with a new seal kit, filter, and B&M shift kit. When the motor goes in I will update next.
Old 04-30-2013, 04:02 PM   #36
Joe Toller
I would like to thank Tony Massari and Bob Shaw for all of their help with info and parts in this build, I would be WAY off without their advice! I especially need to thank you Billy Nees for your inspiration and guidance. Without it I doubt I would have ever seriously tackled this project. Our season opens in June and I can't wait for the payoff!
Old 04-30-2013, 06:57 PM   #37
Billy Nees
Hey, with those two involved you're probably going to have to figure out how to slow it down to keep from getting HP!
Old 05-02-2013, 04:59 AM   #38
Michael Colaluca
I dig it!
Michael Colaluca is offline   Reply With Quote
Old 05-02-2013, 07:27 PM   #39
randy wilson
Liked 22 Times in 22 Posts
Mike, check your PM's
don,t have one
Old 05-16-2013, 12:44 PM   #40
Joe Toller
Just a quick update on the 'Dog, car is all plumbed and wired, and the interior shampooed and I recovered the headliner ($1 worth of fabric from a yard sale), but then I hit a snag: the posi I got, is 30 spline, not 28. Time to choose, find a 28 spline 8.5" posi on the super cheap, or just use an airbag in the RR. That, and getting the drivetrain in, and its payoff time!
