Liked 2 Times in 2 Posts
If you run a 67/68 mustang coupe in D/SA with a 390 what is the minimum weight
3238
Liked 56 Times in 21 Posts
1967-3200
1968-3165
Vic Guilmino 1129 STK |
Also, keep in mind there are different HP factors between the iron and Edelbrock heads. I also believe that the 68 can not use the aluminum intake and larger Holley carb that the 67 is allowed.
Liked 87 Times in 19 Posts
Aluminum heads weight with driver
1967 3277 1968 3239
Rusty Gillis Former NHRA SS/FA and SS/GA record holder |
I did the aluminum heads but you are correct I failed to round up.
NHRA will allow you to round DOWN to the nearest 5#'s.
So you would show 3275 or 3235 on your weight stickers.
Jeff Lee 7494 D/S '70 AMX |
