Guest
Posts: n/a
Does anyone own one of these? Here is the link:
http://www.pro-lineperformance.com/Pro-Line24.htm The price is definitely right as I'm looking to buy my first enclosed trailer and would like to find a solid entry level model. Any input would be appreciated. Thanks! Scott |
Liked 335 Times in 182 Posts
NO-- but see if ya can get 5000 pond axles and 16 inch wheels--- with that you get bigger brakes heavy duty tires and less problems and worries about blow outs and handling too--- FED387
Liked 101 Times in 27 Posts
they are great people to deal with.....down to earth. They used to be STORM trailer dealers and now they are carrying other brands as well as their own. I really like STORM trailers....they are a "medium" quality trailer with all the necessary things that make it road trouble free. Get the 16" wheels and the most expensive axle options you can afford and you will not be sorry. Road speed kills 15" wheels and should not be an option.
NHRA AND IHRA STOCK ELIMINATOR 2772 |
#4 | |
Guest
Posts: n/a
the axle option to get 16" wheels is a 6 lug axle. You will probably find out the 15" deal is also a 5 lug axle, but I have seen 6 lug with 15" tires in rare cases. Move on to another supplier and get a 6 lug 16" wheel even if you have to leave the floor out. 15" tires at 65+ MPH in August road heat are rolling bombs. The revolutions kill the tire dead.
Guest
Posts: n/a
I just checked with them again and to upgrade axles to #5200 is $600 and that requires 6-lug wheels which is another $680. So now instead of being $3900 it's $5200. However, the 6-lug wheel/tire upgrade with the heavier axles is still only 15" radial tires. Would I be able to, when those tires wear out purchase 16" 6-lug wheels with heavier 16" tires? Opinions?
Buy the 5200 pound axles and whatever wheels they put on stock take em-FORGET THE dealer wheels they are rip off---then go look for a set of late model 6 lug GM SUV/Truck aluminum wheels also every boat /camper/ rv trailer uses them they are real easy to find !!!! for a $100-150 and swap the tires over---If you buy the 15 inch wheels I PROMISE YOU WOU WILL BE SORRY!!!!!! while you're at it get a roof vent or 2 keeps the trailer lots cooler and also allows light in when you go in real quick to get something --- if ya can swing it think about maybe getting a 28 footer-- you be surprised how quick ya run out of space with a 24 footer--speaking from experience here
Guest
Posts: n/a
I can't swap the tires over. If you "upgrade" to their 5200# axles for $600 you have to buy their 6-lug wheels for $680 which are 15". If I find another set of 16" wheels I'll have to purchase 16" tires too.
Is there another entry level but quality 24' enclosed trailer with 16" tires? I think that will be plenty long enough since I have a late-model Corvette which is relatively short. |
tell em you dont want any wheels you will provide your own tires too--- ther gonna build the trailer with some kind of wheel/tire combo how else they gonna move it-- but ya want the 5200 pound axles---aske em how much he's gonna knock off for no wheels & tires---you can buy galvanized 16 inch 6 lug trailer wheels for less than $40 each-- tires bout $100 each yer gonna need a spare so ya need 5 wheels & tires 140 per wheel total of 700 +
#10 | |
Guest
Posts: n/a
