#11 | |
David Buckner 4772 |
#12 |
Liked 325 Times in 50 Posts
Well, it's getting better, low Friday 38, high 60 bright sunshine, 37 or Sat, high 60, need to set a record, start driving now for all you northern folks. Hell, I bet a bolt hole or a no bolt hole hemi SS/AH could set a record here.
Jeff Teuton 4022 STK |
#13 |
Liked 1,076 Times in 228 Posts
I guess that means that we'll see a stable of those Southland Mopars all apart this weekend!
#14 |
No, I can't run 10.39 in E like the Findel's can in Minnesota. They got the record. I can't get there. Maybe if I move some bolt holes though. Hmmmmmm Correction: James Findel holds the E/SA at 10.58 and Andrew Hill holds the D/SA record at 10.39; both old cars. Hmmmmmm something amis here. Those combos need hp. F/SA is at a minimum though and I can probably run the 11.35 minimum cause of the good air. With the bolt holes removed. I bet if Andrew Hill took the bolt holes out, he could run 9.99 in D/SA.
Jeff Teuton 4022 STK Last edited by Jeff Teuton; 02-27-2013 at 10:09 AM. Reason: Correction |
#15 | |
Liked 174 Times in 39 Posts
3207 D/SA, C/ED |
#16 |
Just hook up the other two barrels, Jeff. LOL!
Ed Wright 4156 SS/JA |
#17 |
The bolt holes on my heads are hollow, and the air is routed into the throttle body after it gets a dose of blue bottle.
#18 |
I thought the beer was by the can, not the bottle?
3207 D/SA, C/ED |
#19 |
I don't share my beer, not even with my faithful motor Lucky. Today in Baytown, 41 degrees, 30.23 R Barometer, 37 Dew Point, Sunny, Tomorrow Better. Andrew, son, blue bottle does not refer to beer bottle. I worry about you.
#20 |
Liked 175 Times in 78 Posts
So just how good was it?
1320go had it at -900ft - I doubt that Ron
time is our most precious resource, you can always make more money but you can never make more time spend your time wisely with the ones you love - Ron Durham |
