Old 02-23-2013, 02:06 AM   #51
Toby Lang
Liked 2 Times in 1 Post
Default Re: Question for Jeff Foster and Dave Kommel
Originally Posted by Greg Reimer 7376 View Post
What are photographers doing there anyways?
They are there to take the blame for timing system failures, obviously.
Don't know who or what they will blame it on now when it happens again.
Old 02-23-2013, 06:26 AM   #52
Toby Lang
Originally Posted by Michael Beard View Post
3) The above incident, as well as several others that we have seen all show the red light displaying BEFORE the pre-stage and stage lights go out. This is a critical point that everyone continues to completely ignore.
This isn't that big of a deal. The video camera just catches the stage light as it's going out and the red light as it's coming on. Here are just a few examples I found. There are plenty more.
2011 Winternationals, incandescent stage bulbs:
2012 Winternationals, LED stage bulbs:
I have a question for you, Michael, since you seem pretty well versed in the stage-lock system. In Mr. Cotten's meeting with Jeff Foster and Mike Rice they told him: "It is not impossible to have a roll back red light with the stage lock on. But, it requires a motion of at least of a half inch to the rear."
My question to you is: How does the system know if you are a half inch behind the beam? I don't think the computer can tell how far you are behind the beam unless the infrared sensor can tell from how much infrared light it's receiving from the reflector. If not, I would think you could roll back until you turned the pre-stage light off.
And this begs the question, if the infrared sensor can tell how much infrared light it receives, why can't it differentiate between infrared light and a flash from a photographers camera?
Old 02-23-2013, 11:12 AM   #53
partsbob67
Liked 79 Times in 11 Posts
another interesting point is that on another post on here is that someone posted that this doesn't happen at ihra races. wonder if that is true?
bob beals 7244
partsbob67 is offline   Reply With Quote
Old 02-23-2013, 11:36 AM   #54
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
Not a big deal? That is a HUGE deal! With incandescent stage bulbs, it is completely plausible to see the red light prior to the Stage light *appearing* to be out, due to the amount of time that an incandescent bulb retains glow after the power to it ceases. This should NOT be the case with an LED! The stage light going out and red light coming on should appear simulatenous at best. If there was a visibly discernible difference, then the stage light should appear to go out before the red light, not the other way around.
Seeing multiple instances of the red light coming on before the stage light going out makes me MORE concerned, not less.
That'd be a question for Foster.
Old stories:
http://www.competitionplus.com/drag-...-not-red-light
http://www.competitionplus.com/drag-...tem-guard-beam
In the comments section, there was a claim that it happened at Charlotte to multiple cars. So it's guard beams one day, and camera flashes the next...
Old 02-23-2013, 03:06 PM   #55
Toby Lang
Well, both the Brand and Mason red lights happened with the incandescent stage bulbs. And in the DeFrank video, you can see the stage lights are on only in the frame where the red light is starting to come on. So it does happen faster with the LED bulbs. If you had a camera that took more frames per second, I'm sure you could see it on every red light. Most video cameras only take 30 FPS.
They could change the programing to make sure the stage light is completely off before they turn the red light on. The program probably turns the red light on first and then turns the stage light off. Depending on how fast the computer is, there is going to be a little delay.
As somebody said before, they need to overhaul the timing equipment. Starting with a complete rewrite of the software.
Old 02-23-2013, 03:59 PM   #56
Michael Beard
I'd like to see an explanation of how and why the program would be designed that way, if that were the case. The stage light is not a function of the red light. The red light is a function of the stage light in certain circumstances (ie., green light not on, or deep stage foul)
If stage = 0 , then red = 1.
With the exception of a deep stage foul or guard beam trigger, there is no reason for the red light to EVER precede the stage light being off.
What were the results of the flash and infrared triggers testing at Pomona following the race?
Old 02-24-2013, 06:59 AM   #57
James Packer
Liked 3 Times in 2 Posts
If the guard beam is tripped while the pre stage and stage beams are blocked (car staged),the computer thinks the car has moved and starts the clocks. If this happens before the green comes on the red light will be turned on then the pre stage and stage lights will be turned off until the clocks are reset. I believe either something blocked the guard beam or the beam was lost/missing long enough to trigger the red lights for Jimmy Defrank, Mason, Kurt Johnson, and Jack Beckman. It also happened to me in 2011 at a local bracket race.
I don't see how a camera flash had anything to do with these red lights at all unless an intense light or flash could possibly drowned out or weaken the infrared beam so the guard beam sensor doesn't recieve it, but I doubt it. Other possibilities are a bad sensor, bad connection/wiring, or some computer glich. However drivers don't need a flash blinding them so I applaud NHRA for removing that problem.
Compulink needs a recording device that monitors all the sensors during a race so a problem like this could be traced. It would have to be able to read and write at the same time sort of like a DVR opperates.
It would be nice to get a straight answer from NHRA or Compulink when issues like this comes up or at least fix the problem so no one else is becomes a victim of the mysterious red light.
James Packer is online now   Reply With Quote
